Cracked injectors, can I fix?
Old Nov 14, 2006 | 12:52 PM
Maireeka's Avatar
Default Cracked injectors, can I fix?
I pulled my injectors to put in my replacement motor, and to my dismay, two of them were cracked. One has minor hairline cracks, but the other is pretty severe. The motor ran when I pulled it, so could I fix these injectors?
Here's two pics of the bad one:
Here's the one that's not so bad:
Am I buying two new injectors, or can I superglue these? Is the plastic part even necessary? I'm getting really low on funds and I need a running car!
Old Nov 14, 2006 | 01:00 PM
CRX Toad's Avatar
Default Re: Cracked injectors, can I fix? (Maireeka)
You need the plastic part it helps direct the fuel. I would not super glue as the fuel is just going to tear it up again. You maybe able to get new nozzles but I would look into finding some new/used ones. Sorry for the bad news.
Old Nov 14, 2006 | 01:25 PM
user 72830283's Avatar
wow, kinda surprised you didn't have fuel all over, but yea...those aren't woth the repair..you MAY be able to use the plastic sleeves from other injectors, if you're on a tight budget just go to a junkyard and pull them off of another honda or something...good luck..
Old Nov 14, 2006 | 01:30 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: Cracked injectors, can I fix? (CRX Toad)
I think more than anything,the plastic is there to protect
the inner valve if it is dropped..
I have two that were like that in my B16 and it runs fine...
It bugged the hell out of me that they were broken
but to be honest I don't think it had that much effect..
PS:The pintle caps don't appear to be removable...
K2e2vin's Avatar
jb weld that bitch, jk.
It seems easier and cheaper to just buy used injectors.
Old Nov 14, 2006 | 01:54 PM
Boosted Chemist's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad &raquo;</TD></TR><TR><TD CLASS="quote">You need the plastic part it helps direct the fuel. I would not super glue as the fuel is just going to tear it up again. You maybe able to get new nozzles but I would look into finding some new/used ones. Sorry for the bad news.</TD></TR></TABLE>
i dont think the super glue would be a problem, one it polymerizes, its pretty much resistant to any non polar solvent (gas)
Old Nov 14, 2006 | 04:05 PM
Mr_CRX's Avatar
Default Re: Cracked injectors, can I fix? (88DXCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88DXCRX &raquo;</TD></TR><TR><TD CLASS="quote">I think more than anything,the plastic is there to protect
I was under the impression that this is what they were for. Mainly to protect the valve when they are not installed in a manifold. I pulled two injectors out of my d16z6 that looked like this, and it had been running fine.
Old Nov 14, 2006 | 04:37 PM
Got_soy's Avatar
Default Re: Cracked injectors, can I fix? (Mr_CRX)
you could probably check the classifieds and get all four for $15, i have a set sitting in my garage that i have no use for
Old Nov 14, 2006 | 06:01 PM
Maireeka's Avatar
Default Re: Cracked injectors, can I fix? (Got_soy)
want to sell them to me? I have paypal.
Old Nov 14, 2006 | 06:14 PM
Got_soy's Avatar
pmmmed
Old Nov 14, 2006 | 07:34 PM
shortyz21's Avatar
do not replace those.
pull the plastic off and put them back in. all they are for is protection from dropping, they do not direct the fuel in any way.
when removed DONT drop them, it will bend the pintle pin and expletive them forever..
i love it when people just decide to make up their own theory on a part they know nothing about..
Old Nov 14, 2006 | 07:35 PM
Maireeka's Avatar
so the general consensus is that its not good to superglue them? It seems like it's a bad idea since if it were to break off, it would fly into my head/motor/breakeverything, hehe.
Old Nov 14, 2006 | 07:39 PM
Got_soy's Avatar
Default Re: Cracked injectors, can I fix? (shortyz21)
people remove the pintle caps on dsm 450s all the time, why would theese be any different?
Old Nov 15, 2006 | 04:37 AM
jeremydde's Avatar
It's just a protector there are not needed, just be careful when re-installing them back in that you don't hit the center needle sticking out.
Also, honda injectors spray like a squirt gun, they don't fan out just so everyone knows.
Old Nov 15, 2006 | 05:52 AM
Maireeka's Avatar
Default Re: Cracked injectors, can I fix? (jeremydde)
thanks a lot. now I can move on with my swap.
Old Nov 15, 2006 | 08:36 AM
b18sihatch's Avatar
buy new injectors
Old Nov 15, 2006 | 08:47 AM
Got_soy's Avatar
Default Re: Cracked injectors, can I fix? (b18sihatch)
no need
Old Nov 15, 2006 | 09:17 AM
ryan89crx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18sihatch &raquo;</TD></TR><TR><TD CLASS="quote">buy new injectors </TD></TR></TABLE>not everyone likes to throw money away for no reason...
the injectors will work just fine. pull the broken caps off and reinstall then in the motor. 2 of my DSM 450s are missing the caps and my motor has been running fine for 2 years like that
Old Nov 15, 2006 | 09:28 AM
HT Chaplain's Avatar
Loved
i have some you can have for cheap
Old Nov 15, 2006 | 12:44 PM
Maireeka's Avatar
Default Re: Cracked injectors, can I fix? (HT Chaplain)
i'm just gonna pull both broken pintle caps and reinstall the injectors.
Old Nov 15, 2006 | 01:16 PM
Maireeka's Avatar
OK, for those running without pintle caps:
Is it ok to leave a little bit of the plastic material behind? The cap that was very damaged came off cleanly but the other one has a ring of material at the very bottom that I can't get to come out with my hobby knife. I put the injectors in but I can pull them to clean the rest of it off somehow if it is absolutely necessary. I'd hate to have a piece of plastic sucked into my motor.
Old Nov 15, 2006 | 01:56 PM
ryan89crx's Avatar
if you cant get the off with your knife, they obviously wont come off when installed in the IM...
Old Nov 17, 2006 | 05:20 PM
G3NR8's Avatar
Default Re: (ryan89crx)
I have a set if you need them. $20 shipped
sickofitall1113
May 25, 2005 10:22 AM
Tinker219
Jan 27, 2003 03:11 PM
Hnda_Crx_Man
11
Apr 15, 2002 09:40 PM
