T25 turbo bolt up to a t3 flange?
Old Nov 14, 2006 | 11:39 AM
evan938's Avatar
Default T25 turbo bolt up to a t3 flange?
im having a lot of trouble finding a cheap, but somewhat good quality manifold for a t25 turbo for a b series. will a t25 bolt up to a t3 flange, or will there be problems trying to get it to fit?
Old Nov 14, 2006 | 11:49 AM
Jeffescortlx's Avatar
Default Re: T25 turbo bolt up to a t3 flange? (evan938)
The T25 hardly flow's enough to make a strong d, let alone a b.
Your not finding manifolds because that turbo is too small for a b.
Old Nov 14, 2006 | 12:47 PM
pheurton-skeurto's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jeffescortlx &raquo;</TD></TR><TR><TD CLASS="quote">The T25 hardly flow's enough to make a strong d, let alone a b.
Your not finding manifolds because that turbo is too small for a b. </TD></TR></TABLE>
Not entirely true at all. the t25 is a good match for a stock b18b or even a stock b16.
Old Nov 14, 2006 | 12:59 PM
evan938's Avatar
Default Re: T25 turbo bolt up to a t3 flange? (pheurton-skeurto)
this would be a good, true statement, if i were looking to build a massive HP motor. thats not what i am looking for right now. right now i want to get something simple and cheap thrown together for 1500$ or so, get used to boost, work out problems, and upgrade as i go along
a t25 will push 18psi easily...im only looking to run 7-9, maybe 10psi MAX. i dont need 300whp. 220 to the wheels for now id be happy
now instead of debating my decisions on a turbo size, can someone answer my original question?
Old Nov 14, 2006 | 03:20 PM
btotherizzle's Avatar
I'm making 350 whp and 248wtrq with a 18g and pump gas on an itr with lots of mods. Full spool by3k. Ilove this setup
Old Nov 14, 2006 | 09:23 PM
p0gi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by evan938 &raquo;</TD></TR><TR><TD CLASS="quote">im having a lot of trouble finding a cheap, but somewhat good quality manifold for a t25 turbo for a b series. will a t25 bolt up to a t3 flange, or will there be problems trying to get it to fit?</TD></TR></TABLE>
A t25 flanged turbo will not bolt to a t3 flange. You can get an hks manifold that has a t25 flange for about $250. Tony the tiger is making like 380whp with that manifold.
JD95hatch
Oct 14, 2004 01:23 PM
s1ngle
Oct 4, 2004 01:57 PM
fjt
Aug 24, 2004 10:50 AM
PreIudeSI
Jul 22, 2002 06:35 PM
ion_four
May 15, 2002 07:24 PM
