jdm d15b with y8 intake manifold, which injectors?
Old Nov 13, 2006 | 09:15 PM
iphatcrxi's Avatar
Default jdm d15b with y8 intake manifold, which injectors?
my friend has a y8 manifold with fuel rail and injectors, do i need to use them for this to work on a d15b? or can i just use my obd0 injectors and fuel rail on the y8? basically im wanting to know what all do i need for this manifold to work on my d15b.
Old Nov 13, 2006 | 10:11 PM
STREETWERKZ's Avatar
Default Re: jdm d15b with y8 intake manifold, which injectors? (iphatcrxi)
your post and sig confuses me.
you are asking about OBD0 & OBD2 injectors, yet you have OBD1 in your sig.
be a little more clear on what you are doing.
Old Nov 13, 2006 | 10:12 PM
Magick211's Avatar
Just use your stock injectors with the y8 fuel rail, you can also use the y8 injectors but you will have to eliminate the injector resistor box by joing all the wires together at the connection there
Old Nov 14, 2006 | 07:03 AM
iphatcrxi's Avatar
Default Re: jdm d15b with y8 intake manifold, which injectors? (Magick211)
sorry for the confusion, i just converted to obd1 only the ecu and dizzy, the injectors are obd0. are the y8 injectors any better than the obd0, they were from a d16a6.
Old Nov 14, 2006 | 07:08 AM
Autoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iphatcrxi &raquo;</TD></TR><TR><TD CLASS="quote">sorry for the confusion, i just converted to obd1 only the ecu and dizzy, the injectors are obd0. are the y8 injectors any better than the obd0, they were from a d16a6.</TD></TR></TABLE>
no, they are not any better. Use whichever injectors you were using before. Only diff. is one is saturated and one is peak and hold.
Old Nov 14, 2006 | 07:14 AM
iphatcrxi's Avatar
Default Re: jdm d15b with y8 intake manifold, which injectors? (Autoworks)
ok that's all i needed to know, thanks for the replies
Old Nov 14, 2006 | 08:25 AM
both flow about the same.
use the obd-0 injectors. make it easier on yourself.
dont hack a car to pieces for a single cam dude.
Old Nov 14, 2006 | 10:03 AM
iphatcrxi's Avatar
Default Re: jdm d15b with y8 intake manifold, which injectors? (STREETWERKZ)
i like my single cam
Old Nov 14, 2006 | 10:09 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iphatcrxi &raquo;</TD></TR><TR><TD CLASS="quote">i like my single cam </TD></TR></TABLE>
than dont hack it all up.
FeRReTTi
Jun 13, 2015 11:20 AM
xXx Justin xXx
Oct 19, 2005 07:02 PM
dan89crxsi
Mar 25, 2005 09:50 AM
Wes90civic
Feb 22, 2004 07:25 AM
