Neptune
Old Nov 13, 2006 | 07:32 PM
totsie7944's Avatar
Default Neptune
Do I still have to hook up the IAC valve if I plan on tuning with Neptune? Reason being, I just got everything up and running the R tonight, actually got to hear it turn over for the first time in 6 months and I still have 1 vacuum line that used to go to the IM, but now its just kinda hanging.
The only line off the vacuum can I could really put on the IAC would be if I took the one off the black box thingy below the ITB's (don't know what its called but has a nipple for a line) and put it on the IAC.
Old Nov 14, 2006 | 01:50 PM
RTW DC2R's Avatar
Im not sure about this one, dunno how the vacuum lines are set up for ITBs. Id ask Jack at P1, Jeff at http://www.evans-tuning.com forum (boosted hybrid here on HT) or http://www.hrtuning.com forum. That black box you are talking about sounds like the breather box for the PCV return?? That wont work as a vacuum connection AFAIK. I would assume you dont need it at all.
Modified by RTW DC2R at 6:34 PM 11/14/2006
Old Nov 14, 2006 | 09:20 PM
totsie7944's Avatar
Default Re: (RTW DC2R)
haha that black box might be the PCV return, but I put a vacuum line on it haha...I suppose I will just leave it the way I have it and let Jeff look at it Friday when I tow it up there. I had to T into a bunch of lines off the vacuum can to hook up everything so I hope all is well...
I started it tonight and it ran for like 2 seconds like **** and then cut off, back fired, and white smoke came up...I assume its just gas and oil that was burning off from sitting sooo long. Smelled like gas/exhaust so I assume its ok.
I figured it wouldn't run since I added the ITB's, SMSP header, and it is open header right now...
Old Nov 15, 2006 | 05:40 AM
Black R's Avatar
25 Year Member
you don't HAVE to hook up the iacv, but it'll be a pita to maintain a good idle upon coastdown and not shut off...
get a line to your vacuum canister and you'll be straight.
Old Nov 15, 2006 | 09:41 AM
totsie7944's Avatar
Default Re: (Black R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R &raquo;</TD></TR><TR><TD CLASS="quote">you don't HAVE to hook up the iacv, but it'll be a pita to maintain a good idle upon coastdown and not shut off...
get a line to your vacuum canister and you'll be straight.</TD></TR></TABLE>
yea I went ahead and T'ed into another line off the canister and put it on the IAC so now everything is hooked up.
car won't start, except for a split second and shuts off...can't wait to get it tuned.
Old Nov 15, 2006 | 09:59 AM
Bradstard's Avatar
Default Re: (totsie7944)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by totsie7944 &raquo;</TD></TR><TR><TD CLASS="quote">
Type R TB and IM...not sure about cost yet
I would hang on to these until you get your ITB's tuned and you are happy with them.
blacktibby07
May 27, 2011 06:23 PM
wtsapexipowerfc
Nov 18, 2010 09:47 AM
K_1
14
Aug 23, 2007 06:14 AM
dizzyek
Nov 16, 2006 04:38 PM
Art701
15
Oct 25, 2004 06:25 PM
