Weird Lighting problem
Old Nov 13, 2006 | 05:21 PM
Hatched_out's Avatar
Default Weird Lighting problem
I have this weird problem with my civic
when i turn on my headlights i have no interior lights or rear running lights.
but when i only have on my corner lights i have all instrument lights and the rear running lights.
what could this be, i know prolly a fuse but i checked the headlight fuses and they were ok, plus the headlighs work, just not in conjunction with the inside lights
Old Nov 13, 2006 | 05:39 PM
92 CIVIC HATCH VX's Avatar
Default Re: Weird Lighting problem (Hatched_out)
check fues one more time. also make sure none of the lights are out and they all work.
Old Nov 13, 2006 | 05:44 PM
hatch96y7's Avatar
Default Re: Weird Lighting problem (92 CIVIC HATCH VX)
check all ur fuses under ur dash
and only replace them with the same amp rating
Old Nov 13, 2006 | 05:50 PM
nighttrain33's Avatar
The rears may be on a separate fuse, as is the case with my truck. It has been a while since I looked at the fuses in my car, but when my GM dealer fixed my tranny under warranty, they forgot to plug my rear wire harness.
Luckily, I noticed that none of my turn signals nor brakes worked, as they had before the work, so I figured they forgot to plug something in.
In any event, the rear lights may be on a separate fuse, and this is what is causing your trouble.
-Shane
Old Nov 13, 2006 | 06:17 PM
it fixed itself?
i am thinking it was my dash leds
i had changed all the bulbs out to leds a while back, when they arrived it warned me not to turn the lights on and then start the motor, always start the car then cut lights on ?
but it fixed itself
Old Nov 19, 2006 | 03:29 PM
problem is back
I can either have ( parking lights + dash lights + tail/licence lights) or i can have ( headlights ) and nothing else....
when i go from parking light position to lights, the dash and rear lights will all cut off...
what could this be, all fuses are working and all the lights work, just nothing together
Old Nov 19, 2006 | 03:52 PM
Default Re: (Hatched_out)
bump
Old Nov 19, 2006 | 04:45 PM
I also have the oem foglights on the car, when i switch from the parking lights to the dash lights the relay on the fog lights will click in my hand real loud, but they do work...
i have no idea what is wrong with this car.
its like everything works , just not at the same time?
Old Nov 19, 2006 | 04:56 PM
juzthewy's Avatar
electrical problems =
Old Nov 19, 2006 | 04:57 PM
Default Re: (juzthewy)
bump
Old Nov 19, 2006 | 05:02 PM
I looked up in my chiltons and still no luck,
I cannot figure out what is wrong, everythign works on the car, just not at the same time, i am not sure what is makeing the instrument lights corners and tails all go out when the headlights come on....
Old Nov 19, 2006 | 06:33 PM
bump
Old Mar 13, 2007 | 01:54 PM
blkhondaex's Avatar
damn, dude do you still have this car or what?
zenon8890
Mar 28, 2009 03:34 PM
mel
12
Nov 9, 2006 09:04 AM
Tee Jay
Feb 23, 2004 04:59 PM
