oil filter relocation...location
Just wanting to see if the spot Ive chosen to mount my filter is ok...
It is kinda high...dont want the pump to work harder than it has to (obd2 b series)
Right now, its just mounted with a pre-existing weldnut, to see if the spot is alright.
Should I lower it?
Yes, the hood closes
I know...theres no head on the car, but there is the IM... I didnt have room for the manifold anywhere, so this keeps it out of my way
Should I lower it?
both of you guys do have a point... but logically when i think about... if your planning on doing a oil change right away after you shut off your car...i think it will be messy. but if you give it time to drain down...i think it will be clean and easy :D ...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense »</TD></TR><TR><TD CLASS="quote">damn dude, your bay is dirtier than mine.
you got clutter AND dirt lol!</TD></TR></TABLE>
I dont care about having a clean bay...its a DD! ...when it ran...
I miss driving it...
Its not that cluttered...is it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMFreak »</TD></TR><TR><TD CLASS="quote"> if you give it time to drain down...i think it will be clean and easy :D ... </TD></TR></TABLE>
What do you mean "drain it down"? Why wouldnt it do this on its own?
Main reason why its where it is...is because I dont know where else to put it! That filter big enough to eat out of doesnt help...and I am going to find a smaller one that fits, but still...
I miss driving it...Its not that cluttered...is it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">I dont care about having a clean bay...its a DD! ...when it ran...
Its not that cluttered...is it?</TD></TR></TABLE>
lol, I'm the same way, I just wanted to give ya hell
I miss driving it...Its not that cluttered...is it?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense »</TD></TR><TR><TD CLASS="quote">lol, I'm the same way, I just wanted to give ya hell
Good lookin out
</TD></TR></TABLE>Good lookin out
Except he has a GSR motor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMFreak »</TD></TR><TR><TD CLASS="quote">both of you guys do have a point... but logically when i think about... if your planning on doing a oil change right away after you shut off your car...i think it will be messy. but if you give it time to drain down...i think it will be clean and easy :D ... </TD></TR></TABLE>
Depending on how you mean "drain down." My truck filter is the exact opposite as far as how the filter drains. It is messy as crap. No matter how long it sits. But, that looks easy as heck to change. Besides, who changes their oil right after shutting off their car?
-Shane
.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMFreak »</TD></TR><TR><TD CLASS="quote">both of you guys do have a point... but logically when i think about... if your planning on doing a oil change right away after you shut off your car...i think it will be messy. but if you give it time to drain down...i think it will be clean and easy :D ... </TD></TR></TABLE>
-Shane
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">That filter big enough to eat out of doesnt help</TD></TR></TABLE>
I noticed this. Is that the way all GSR filters are? Heck, my 5.3 filter looks barely as large.
-Shane
-Shane
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nighttrain33 »</TD></TR><TR><TD CLASS="quote">Except he has a GSR motor
-Shane</TD></TR></TABLE>
B18B ftw
The filter is a fram PH8A, the standard for relocation kits...I hate it... Its for Fords and the honda filter is dwarfed by it. I guess a Suzuki Areo filter is the same thread pitch, and is what I am going to check out, maybe tomorrow.
If it just has to sit for a few mins to "drain it down" thats fine...I do it that way anyways - I let the pan finish before I remove the filter.
B18B ftw
know that the stock location is sideway... or toward the motor... and since he has his oil filter upside down...which mean the oil should drain down will you have your motor sit over night...
example: I usually do my oil change in the morning... when I take out the oil filter there is little to no oil left in the oil filter... kind of like the same concept on what pdiggitydogg is going... unless your oil does not drip back I guess it bad...
I see what you are saying. I hate changing my truck filter, because no matter how careful I am, it gets all over my arm because of the way it is positioned.
-Shane
-Shane
dont filters have a valve to retain oil to avoid dry start? Why would you relocate the filter? I got a B16 and dont need to get the filter off from underneath, just reach underneath the manifold.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeadEnd9009 »</TD></TR><TR><TD CLASS="quote">dont filters have a valve to retain oil to avoid dry start? Why would you relocate the filter? I got a B16 and dont need to get the filter off from underneath, just reach underneath the manifold.</TD></TR></TABLE>
Umm, have you seen how easily accessible his filter is? I know it is not that hard to replace when it is stock, but this way is obviously easier.
-Shane
-Shane
Dont really care about your opinion of how it looks...thanks
tech comments only
I have a relocation kit because of an oil cooler
(knew I should have said that to avoid people saying "why do you have that?")
Oil cooler to keep temperatures down, boosted application - dont always have time to let the car idle for 2+ mins and turbo timer does not work with my alarm setup.
tech comments only
hey dont feel bad on what people say... as long as it work and there is no issue...im all
for you bro... :D i was thinking about doing the same thing but at a different location.... becuase we know how we are...we are lazy
and trying to make things easier in life.... but i was afraid of extending the line to a different location will cause lower oil pressure flowing back and forth...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">Dont really care about your opinion of how it looks...thanks
tech comments only
thanks, i heart you too.
tech comments only
