@ low rpms my lude is very hesitant......
Old Nov 13, 2006 | 02:26 PM
miguel_aka_timon's Avatar
Default @ low rpms my lude is very hesitant......
When im changing gears and my rpms drop below 3k or when im begining to take off on 1st gear my car sputters or jerks horribly...and doesnt acceerate like it use 2
Can anyone help me if this has happened to your h22a lude?
Since i bought the car like 2 yrs ago i never changed the fuel pump or filter..would that have an effect like this? or would it be that i need to fix my timong belt...
PLZ HELP ANY1!!!
Old Nov 13, 2006 | 02:46 PM
Default Re: @ low rpms my lude is very hesitant...... (miguel_aka_timon)
oh yea... i have 3 codes after did motor swap...vtec selonoid, o2 sensor, and knock sensor.
Old Nov 13, 2006 | 03:28 PM
dek1mfk's Avatar
dude, first thing i would recommend getting fixed is the o2 sensor...if there is one thing about h22 ECU's...its that they are sensitive to sensors....
i did my swap and have not wired vtec so i dont have to worry about the knock sensor for now, or vtec solenoid, but mine is also throwing the CEL code for o2 sensor...so i think thats what causes it to hessitate like you....
forget about vtec for now, worry about your lower end hessitation, then worry about vtec
Old Nov 14, 2006 | 08:15 AM
JDMhondalude22's Avatar
Default Re: @ low rpms my lude is very hesitant...... (dek1mfk)
i also have this hesitation, with h22a swap, with 02 sensor cel. , with code 21, and vtec works. codes come and go as they please, the only difference i notice is that it gets hesitant when the light comes on. but vtec still works at all times.
Old Nov 14, 2006 | 11:50 AM
Default Re: @ low rpms my lude is very hesitant...... (JDMhondalude22)
well when the light turns on; i hear my vtec but it doesnt pik up like it use to..
I've already changed the knock sensor n vtec selonoid.. but i still get the same codes..
So what i need to try next is to change my o2 and see if my fuel pump is trashed ..
HUYNH
Aug 2, 2006 01:00 AM
EF9ZC
Apr 8, 2006 11:08 AM
sctan15
Aug 23, 2003 01:51 PM
EF_LSVtec
Feb 21, 2003 07:59 AM
22civic
Aug 21, 2002 12:08 AM
