anyone have problems with their apex world sport exh?
Old Nov 13, 2006 | 02:19 PM
dan89crxsi's Avatar
Default anyone have problems with their apex world sport exh?
I put my apex world sport exhaust on my 99 ex coupe and it hangs down very low but everything is on the hangers that are there and everything is bolted up right. I scrape on speedbumps etc and my car is not lowered at all. Anyone have this problem or know of a possible solution?
Old Nov 13, 2006 | 02:24 PM
byronl's Avatar
Default Re: anyone have problems with their apex world sport exh? (dan89crxsi)
is the muffler hanging low or the resonator?
Old Nov 13, 2006 | 02:32 PM
dan89crxsi's Avatar
Default Re: anyone have problems with their apex world sport exh? (byronl)
oh sorry yeah its the resonator the mid section under the middle of the car is hanging low and where the resonator connects to the s pipe
Old Nov 13, 2006 | 08:07 PM
dan89crxsi's Avatar
nobody?
Old Nov 13, 2006 | 08:23 PM
instrument's Avatar
is it a crx?
stock suspension?
attack speed bump and everything else at an angle and you'll be fine.
my resonator always scraped on my 91 si, though it was lowered...
its part of the fun.
Old Nov 13, 2006 | 08:25 PM
dan89crxsi's Avatar
Default Re: (instrument)
no its a ek coupe i want to lower my car and its already scraping without it lowered thats not good
Old Nov 13, 2006 | 08:42 PM
SGVridgerunner's Avatar
Default Re: (dan89crxsi)
I have a WS2 on my GSR, I never scrape, and it's lowered.
Hmmmm, is your headers/exhaust manifold bolted up (rear support)? Is your cat bolted up straight? Check your hangers for the mid pipe, make sure nothing got bent on install.
Old Nov 13, 2006 | 09:16 PM
dan89crxsi's Avatar
Default Re: (SGVridgerunner)
ill have to post pics this low exhaust **** is bothering me
Old Nov 13, 2006 | 11:16 PM
Gunns's Avatar
When I track my hatch the muffler comes out of the rubber hangers. Yes it is installed right. It might be my thief like driving.
Old Nov 13, 2006 | 11:46 PM
byronl's Avatar
i've read this somewhere where this guy had the same exact problem as yours. He had bolted his resonator on upside down. Try taking out ur resonator and flip it over and bolt it on again and see if it hangs low.
Old Nov 14, 2006 | 10:33 PM
dan89crxsi's Avatar
i did that already hehe oops late night exhaust install before work......resonator has been flipped to correct position but i did that before i made this post it bothered me after i flipped it and noticed it was still fairly low to the ground my resonator has two hangers on it but the car only has one for the resonator is that normal? never owned an ek before i noticed on the same exhaust on an eg both hangers on the resonator are used in my case i could only use one (ek)
Old Nov 14, 2006 | 10:42 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
The first gen WS hangs low.... no idea about the second gen.
Old Nov 15, 2006 | 06:46 AM
byronl's Avatar
well i guess if nothin else works, then you can go to a muffler shop and have them fix it for you.
Old Nov 15, 2006 | 06:52 AM
jdmztrane's Avatar
Second gen should't touch the ground at all. Im about 2.5 inches lower than stock and I dont scrape unless i go over a speed bump. The only thing I have problems with is the fact that the damn exhaust touches my shifter now and rattles like crazy. I guess being lowered has its consequences.
user 98292739
14
Mar 3, 2008 08:54 AM
ShinyNewPenny
13
Feb 3, 2008 05:09 AM
4thgenx42
12
Jul 18, 2007 08:32 AM
Gizzo
May 9, 2005 06:29 PM
Jet Black
Dec 4, 2003 03:11 PM
