Starter won't stop spinning without keys in ignition.
Old Nov 13, 2006 | 01:44 PM
hondacivicowner's Avatar
Default Starter won't stop spinning without keys in ignition.
This is not in a Honda, it's in a 2000 Toyota 4Runner. There used to be a clicking sound when I tried to start the car before, but it would always eventually start. Today, I started the car and the starter wouldn't stop cranking even with keys out of ignition. What can it be? Do I need to replace ignition cylinder? Starter solenoid (no)?
Thanks in advance.
Old Nov 13, 2006 | 02:15 PM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
Default Re: Starter won't stop spinning without keys in ignition. (hondacivicowner)
that sounds like something in the ignition...would go that way first
Old Nov 13, 2006 | 02:19 PM
lightcrx's Avatar
ignition switch getting stuck.. take it apart and clean the contacts
Old Nov 13, 2006 | 04:16 PM
02 accord's Avatar
Default Re: (lightcrx)
Could also be the starter contacts getting stuck. Check both.
Old Nov 13, 2006 | 04:17 PM
BuddhaSiR's Avatar
check for 12VDC at the starter. The big fat wire is going to have voltage. The smaller wire comes from the ignition switch. Unplug the little wire check for voltage. Should only have voltage while starting the engine.
Old Nov 13, 2006 | 10:00 PM
93lsd's Avatar
ign. switch is getting stuck i have changed some on new tacomas 04-05 models, you may wanna contact the dealer there may be a recall on that model
Old Nov 15, 2006 | 12:53 PM
Perfectionist's Avatar
Or... the starter bendix (the part that the solenoid pushes out to engage the flywheel) is gummed up and not returning to the rest position. Or possibly the solenoid itself is sticking.
Old Nov 15, 2006 | 01:50 PM
Default Re: Starter won't stop spinning without keys in ignition. (Perfectionist)
I changed ignition switch and that wasn't it. Next I'll pull the starter out (looks like it's going to be bitch) and check the solenoid. Thank you all for suggestions.
Old Nov 15, 2006 | 08:45 PM
FrankT's Avatar
Default Contacts are worn and sticking inside the solenoid
Your starter contacts are worn and sticking inside the solenoid.
Repalce your contacts! A 15 minute repair once your starter is out.
Here is a link that will help you fix your starter
http://www.4crawler.com/4x4/Ch...ering
Here is a link that will help you with the removal. I do belive you have a 3.4...
http://www.yotatech.com/~corey...e.htm
Good luck
Old Nov 16, 2006 | 11:40 AM
BuddhaSiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondacivicowner &raquo;</TD></TR><TR><TD CLASS="quote">I changed ignition switch and that wasn't it. </TD></TR></TABLE>
This is why I check things first before i assume its anything. How much did that switch cost you?
Old Nov 17, 2006 | 06:01 AM
Default Re: Starter won't stop spinning without keys in ignition. (BuddhaSiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BuddhaSiR &raquo;</TD></TR><TR><TD CLASS="quote">
This is why I check things first before i assume its anything. How much did that switch cost you?</TD></TR></TABLE>
I actually had a whole steering column out of a 1998, so that was free. I did buy a starter relay and it was about $50. Relay wasn't the problem though and they didn't let me return it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FrankT &raquo;</TD></TR><TR><TD CLASS="quote">Your starter contacts are worn and sticking inside the solenoid.
Good luck </TD></TR></TABLE>
I'll buy the contact kit and try that next. Thanks all.
Old Nov 19, 2006 | 03:12 PM
Contacts it is. I hit the starter with a bar and it solved the problem (probably temporarilly ). I should have done that from the start. I'll replace them in the next few days. Sorry for bumping my own old thread, just wanted it to have "closure".
Old Nov 20, 2006 | 06:39 AM
FrankT's Avatar
Thanks for letting us know what happened.
There is nothing worse than a thread like this with no outcome or closeure.
Enjoy your rebuilt starter
Old Nov 25, 2006 | 02:45 PM
frostyrb's Avatar
Default Re: Starter won't stop spinning without keys in ignition. (FrankT)
I am a toyota tech, & I wish I would have seen this thread earlier. We have a lot of problems with worn contacts in our starters, but the nice thing is you can service most of them. That saves you lots of money especially if you can do the work yourself.
mafia
Jun 6, 2014 11:26 AM
apm
10
Mar 30, 2013 08:57 PM
chunk3rs
11
Jun 6, 2007 11:58 AM
EG6-SIRII
Jan 12, 2007 01:50 PM
94coupeNA
Jul 6, 2004 07:50 AM
