Rear Disk Brake Conversions!!
Old Nov 13, 2006 | 08:40 AM
MikeySpec's Avatar
Default Rear Disk Brake Conversions!!
Ultra mint. No rust. Straight out of japan with ebrake cables from a 92-95 civic. Still has the comp arms and upper control arms attached. Dont waste your time with shitty midwestern rusty hacked up rear disks. These are ready to bolt up to your 88-00 civic. Asking 250- 3 sets to choose from
Mikey
Old Nov 13, 2006 | 09:30 AM
hoffmann277's Avatar
Default Re: Rear Disk Brake Conversions!! (MikeySpec)
Would you happen to know if these would also work for a CRX, a HF in particular, and also the brand disks?
Old Nov 13, 2006 | 02:34 PM
SILVER97EX's Avatar
Default Re: Rear Disk Brake Conversions!! (hoffmann277)
do those e-brake cables work on the 96-00?
Old Nov 13, 2006 | 04:26 PM
MikeySpec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hoffmann277 &raquo;</TD></TR><TR><TD CLASS="quote">Would you happen to know if these would also work for a CRX, a HF in particular, and also the brand disks?</TD></TR></TABLE>
Yes, but you will have to get 90-91 ebrake cables. To do it correctly you need a 91 civic ex master cyl and a prop valve from a 90-93 integra. These are oem rear trailing arms complete with calipers off of a japanese 92-95 civic sir.
And as far as the ebrake cables working on a 96-00 civic. I know almost for definite they work on the hatchbacks, and from what i remember the coupes are the same difference. So yes, it should work. But i'd like for someone to double verify this.
Mikey
Old Nov 15, 2006 | 01:29 AM
Don't know if it's appropriate to ask here but would there be a better/easier route to take for an HF? The yards around here short on Hondas in general.
Old Nov 15, 2006 | 11:16 AM
MikeySpec's Avatar
Well on top of having a hard time finding a set of trailing arms in the midwest, the ones you find will be crusty and rusty. On top of all else youll have to remove them yourself. Its not fun dealing with seized bolts in a junkyard in the winter time. Then you might even get charged around 200 dollars for them. Save yourself the trouble and check out these clean ones. Then just buy crx ebrake cables and buy some fresh rear brake lines and be done.
Old Nov 15, 2006 | 11:35 AM
Have any pics?
Old Jan 17, 2007 | 06:55 PM
94gsr_teg's Avatar
pmed
Old Jan 18, 2007 | 02:27 PM
MikeySpec's Avatar
Default Re: Rear Disk Brake Conversions!! (94gsr_teg)
250 each pair. These clean sets come complete with cables from 92-95 SiR honda civic's. All sets have comp. arms and upper control arms. Rust free. No seized or broken bushings. Ready to install! Located in Schaumburg.
Old Jan 19, 2007 | 01:12 PM
chinese acrobat's Avatar
Ill def buy a pair once i sell my wheels.
Old Jan 19, 2007 | 03:55 PM
SOHC LO's Avatar
How much for install. I got a 98 civic coupe. I would want to put them in myself NOW but its way to cold =P. Gimme a PM
solidinside
Jul 29, 2007 01:40 AM
twotonecivic
Jan 18, 2007 06:54 PM
ED3_FTW
Dec 16, 2006 04:32 PM
vtecb20coupe
Jul 8, 2004 12:26 PM
ef9one6
May 28, 2003 10:33 PM
