Why do P29 Pistons make for higher CR in a d16a6 when they have the dame bore/stroke...
Old Nov 12, 2006 | 09:57 PM
gurippugasuki's Avatar
Default Why do P29 Pistons make for higher CR in a d16a6 when they have the same bore/stroke...
I am confused as to why people put p29 pistons out of a d16a3 into d16a6's to boost their cr. Both engines have the same bore and stroke--75x90. Is the d16a6 head shorter?
Old Nov 13, 2006 | 05:15 AM
gibsanez's Avatar
Default Re: Why do P29 Pistons make for higher CR in a d16a6 when they have the same bore/stroke... (gurippu
It's soley to do with the dome or dish of the piston
Edit - not a d series guy, so the heads may have different combustion chamber volumes as well.
Old Nov 13, 2006 | 08:31 AM
b18sihatch's Avatar
domed
Old Nov 13, 2006 | 10:18 AM
Wes V's Avatar
It could also be due to the placement of the pin in the piston.
If you had two different pistons, both with flat top's, the placement (height) of the pin could make a difference.
Wes
Old Nov 13, 2006 | 11:00 AM
Bense's Avatar
the dohc p29 combustion chamber is much larger than a d16a6 combustion chamber.
Old Nov 13, 2006 | 05:19 PM
Default Re: (Bense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense &raquo;</TD></TR><TR><TD CLASS="quote">the dohc p29 combustion chamber is much larger than a d16a6 combustion chamber. </TD></TR></TABLE>
Ah, this makes sense. Thanks.
Old Nov 13, 2006 | 08:02 PM
SMSP's Avatar
Default Re: (Bense)
And the P29 dome is much bigger than the PM3 (?) dome.
Here are mine.
BTW, this engine is for sale.
https://honda-tech.com/zerothread?id=1750498
devious_yeti
May 2, 2016 07:30 PM
.adam.
Nov 21, 2007 02:39 PM
hatchinprogress
Nov 14, 2005 05:33 PM
dude_123
Sep 29, 2005 08:02 AM
Benny Z
Dec 20, 2002 03:35 AM
