bad sensor?? please help
Old Nov 12, 2006 | 07:57 PM
kaneda3's Avatar
Default bad sensor?? please help
ok i have a b18c swapped 98 hatch
it running a rather high compression ratio and built head + cams
anyway the car is rom tuned and was running really well for quite sometime but last night passed some traffic last night and as soon as i let off the throttle the car started backfiring and ran like poo at anything less then 60% throttle
anytime i came to stop it either stalled or came close to stalling
eventually the check engine light came on and the car started running fine, with a slightly higher idle then normal.
problem is, once i got to my destination and turned the car off the check engine light reset and the car is running like *** again.
anyone ever have a similar problem?
will an obdII diagnostic tool tell me whats wrong without the check engine light on?
please get back to me asap
and thanks in advance
mike
Old Nov 13, 2006 | 12:23 PM
kaneda3's Avatar
Default Re: bad sensor?? please help (kaneda3)
any ideas?
Old Nov 14, 2006 | 06:27 PM
kaneda3's Avatar
helllloooooo
well ok answer me this
i was told by friend to disconnect and reconnect my ecu
im willing to try this but i need to know if this can potentially F up my tune?
any one????
Old Nov 15, 2006 | 12:42 PM
Perfectionist's Avatar
No ideas, but the engine runs OK in open loop (CEL on). That would lead me to believe you've got sensor or wiring issues to investigate.
Old Nov 17, 2006 | 12:12 AM
kaneda3's Avatar
Default Re: bad sensor?? please help (Perfectionist)
thank you very much for responding
im thinking more and more that is my o2 censor
as its running overly rich now, its been raining for the past few days so i havent had a chance to inspect it
mcnos
Dec 18, 2011 11:53 AM
dd69ma
Feb 1, 2006 07:58 PM
GSRTURBO696911
Oct 21, 2005 09:55 PM
champwhiteitr
Mar 17, 2004 03:39 PM
waijsR
Oct 30, 2003 01:43 AM
