h22 swap question
use the search button at the top right...
Its RED!
But all you really have to do is change the fuel rail, wire in vtec, umm....thats all i can think of right now...search will tell you EVERYTHING!
Its RED!
http://www.superhonda.com/foru...41207
there is the link im goin off of,,,,, now i have 1 more question,,, would it be easier to just unhook the engine wireharness from the H22 firewall and replace the H23 wireharness,,,,???? simple question,,, thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PWRDbyHseries »</TD></TR><TR><TD CLASS="quote">http://www.superhonda.com/foru...41207
there is the link im goin off of,,,,, now i have 1 more question,,, would it be easier to just unhook the engine wireharness from the H22 firewall and replace the H23 wireharness,,,,???? simple question,,, thanks</TD></TR></TABLE>
theres no need...all you need to do is wire 2 wires from the ecu
ok thanks,,, i didnt know if there would have been nething else or not,,, im doin this swap this week most likely by the way, and HT has been a big help on everthing that i have needed...
ok b4 i start this swap,, im just double checking some things,,, when i drop the H22 in, all the wires from the H23 harness will pulg in, and the only thing that i will have to wire up would have to be VTEC, correct?,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PWRDbyHseries »</TD></TR><TR><TD CLASS="quote">ok b4 i start this swap,, im just double checking some things,,, when i drop the H22 in, all the wires from the H23 harness will pulg in, and the only thing that i will have to wire up would have to be VTEC, correct?, </TD></TR></TABLE> Yes
Wire vtak
You can re-use your usdm H23 distributor and external coil.
Re-use the usdm fuel rail- use H22 injectors and fuel pressure regulator.
Wire vtak
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PWRDbyHseries »</TD></TR><TR><TD CLASS="quote">thanks for the help,,,, ill post later on when i get everything done, and show some pics</TD></TR></TABLE>
sounds good...and good luck. hopefully you dont encounter the 3k hesitation like a lot of people do.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteBB2 »</TD></TR><TR><TD CLASS="quote">
sounds good...and good luck. hopefully you dont encounter the 3k hesitation like a lot of people do.</TD></TR></TABLE>
what all is wrong with yours
ive seen ppl say on other boards that you can take the H22 engine harness and swap it with the H23,,, so i think that i might try that and use my H22 ignition coil.... if not then ill use the H23 harness and coil,,, Either way ill keep you all posted
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AndyD »</TD></TR><TR><TD CLASS="quote">The hardest part I encountered was getting the trans mount to line up. That was the only snag I ran into.</TD></TR></TABLE>
any problems with it so far???
any problems with it so far???</TD></TR></TABLE>
With my H22? I've had it in my car for a little over 2 years. 10+ track events and daily driving and not ONE problem.
I even dynoed at 179 whp with just an intake and exhaust.
ok well my RHD lude came with a f22b .. will my harness do that "3k hesitation" problem that u say it encpunters ??? and does anyone know of any stock or aftermarket headers for sale ??
