timing belt walking
Old Nov 12, 2006 | 04:14 PM
924door's Avatar
Default timing belt walking
I just put a new timing belt and waterpump on my b16. when letting it warm up you could hear some rubbing so i took off the valve cover and its rubbing on the plastic cover on the waterpump side. Any ideas?
Old Nov 12, 2006 | 04:36 PM
PrettyLude's Avatar
did you put the black retainer on the crank gear back? the piece that goes on the inside of the timing cover
Old Nov 12, 2006 | 06:36 PM
93lsd's Avatar
you might wanna see if you have any slack in the timming belt it might be flappy by the water cover area
Old Nov 13, 2006 | 09:10 AM
Cory man's Avatar
Default Re: timing belt walking (924door)
Make sure you reinstalled the tbelt guide washers correctly.
Old Nov 13, 2006 | 09:46 AM
kevmugen's Avatar
Default Re: timing belt walking (Cory man)
take the black cover off, weight reduction... muahahaha
Old Nov 13, 2006 | 01:11 PM
IntegraType-R's Avatar
Default Re: timing belt walking (kevmugen)
I have no T-belt covers on my type-r..i find everything is more accessible and its been like this for almost a year with no problems..
There's a HUGE *** washer/retainer that goes on the crank pully gear, behind the crank pully itself, its slightly bent outward to allow the bent to lend/rub against this to keep it on track..I'm quite sure you forgot to put this on there, as this is the only thing that keeps the timing belt from walking..Double check it, because i also caught my buddy doing this same thing..and FYI
its quite safe if u know how to drive to run without the covers..if your that "scaried" put the lower portion back on, but i'd run without the top half at least..it makes everything around it more accessible.
732xghost
Sep 9, 2007 10:02 AM
BlueShadow
Jan 12, 2005 08:38 PM
SpoonFedHatch
Nov 13, 2003 08:23 PM
Honda Kustums
Aug 19, 2003 06:36 PM
