Car shut off while driving and no power....
Old Nov 12, 2006 | 02:30 PM
R-81 Coupe's Avatar
Default Car shut off while driving and no power....
My car shutted off on me while I was driving and I was getting no power. When I try to start it I can hear a click coming from the passenger side and a rapid clicking coming from the engine. The hazard light was really low when i turned it on. I had someone jump started it for me and it started back up. When i got home, I shutted the car off and now it won't start agian unless you jump it. Anyone know what's wrong?
thanks.
Modified by R-81 Coupe at 4:09 PM 11/12/2006
Old Nov 12, 2006 | 02:34 PM
Eran's Avatar
HT White Ops
Battery, alternator, or starter. Get a jump, go to autozone, and have them test all three.
Old Nov 12, 2006 | 02:52 PM
B16B_coupe's Avatar
HRD PKR
Default Re: (Eran)
put a battery in it
Old Nov 12, 2006 | 06:48 PM
dorifto_83's Avatar
also check alternator fuse
Old Nov 12, 2006 | 06:55 PM
JDM-97CX's Avatar
Default Re: (dorifto_83)
Battery is definitely bad. Alternator is most likely bad as well. The alternator should be able to provide sufficient power to run the car even with a bad battery.
If the starter was bad it would not start even when jumped.
Old Nov 12, 2006 | 06:58 PM
Archidictus's Avatar
Unceasing Measure
Default Re: (JDM-97CX)
The clicking indicates that the starter is good, but there is insufficient voltage to make it function. Replace battery and alternator and you're golden.
Also...shutted? Really? Shutted? Does it make sense when you say that out loud? Not shut, but shutted? Is that like a more extreme shut? I hate you a little bit.
Old Nov 12, 2006 | 08:12 PM
skankz_em1's Avatar
Default Re: (Archidictus)
and check the ground wires if they are loose...thats what happened to me
Old Nov 13, 2006 | 05:32 AM
R-81 Coupe's Avatar
Default Re: (123lbc)
okay thanks for the help.
Old Nov 13, 2006 | 05:38 AM
DSRxNATE DNRperformance's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">The clicking indicates that the starter is good, but there is insufficient voltage to make it function. Replace battery and alternator and you're golden.
Also...shutted? Really? Shutted? Does it make sense when you say that out loud? Not shut, but shutted? Is that like a more extreme shut? I hate you a little bit.</TD></TR></TABLE>
Old Nov 13, 2006 | 05:46 AM
JDM_teh_WIN!!'s Avatar
Default Re: (DSRxNATE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote"> I hate you a little bit.</TD></TR></TABLE>
LOL.
Old Nov 13, 2006 | 08:23 AM
R-81 Coupe's Avatar
Default Re: (JDM_teh_WIN!!)
Can a bad battery or ground make your car shut off when it's running?
Old Nov 13, 2006 | 09:16 AM
Eran's Avatar
HT White Ops
Default Re: (R-81 Coupe)
No, but an alternator can.
Old Nov 13, 2006 | 09:31 AM
JDMFantasy2k's Avatar
Default Re: (Eran)
or a bad positive connection to the alternator/battery
Old Nov 13, 2006 | 10:16 AM
JDM_Window_Regulator's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R-81 Coupe &raquo;</TD></TR><TR><TD CLASS="quote">^
Can a bad battery or ground make your car shut off when it's running? </TD></TR></TABLE>
All electronical stuff will shut off (Bad terminal connection)
Old Nov 13, 2006 | 11:10 AM
skunkcoupe's Avatar
Default Re: (JDM_Window_Regulator)
happened to me after my swap! it was ground wires FTL
Old Nov 13, 2006 | 11:50 AM
dorifto_83's Avatar
I had a poor ground and it would make my car turn off. Check ground connectinos definitely
Old Nov 13, 2006 | 12:46 PM
R-81 Coupe's Avatar
Took my battery to autozone and they told me it was bad so they charged it for me. When I got home I putted the battery back on and it started back up like a champ.. but after driving it around for half an hour to test it out. It die on me agian I'm thinking it's the battery.
Modified by R-81 Coupe at 5:20 PM 11/13/2006
Old Nov 15, 2006 | 10:11 AM
hondatech866's Avatar
Default Re: Car shut off while driving and no power.... (R-81 Coupe)
hey man it sounds like your alternator is not charging. That's why when you put a new battery in you can run the car for a while but as soon as the battery loses voltage the car will die. you can check to see if the alternator is charging by turning the car on and checking battery voltage. if you have 14.5 volts while car is running then alternator is working. if not check alternator fuse. if that fuse is good check ground and if ground is good then your alternator is bad.
Old Nov 15, 2006 | 07:37 PM
R-81 Coupe's Avatar
Default Re: Car shut off while driving and no power.... (hondatech866)
replaced my alternator but car still die...
Old Nov 15, 2006 | 08:23 PM
Marcpb443's Avatar
Did you replace the battery?
Old Nov 16, 2006 | 05:38 AM
tEKnics's Avatar
Default Re: Car shut off while driving and no power.... (Marcpb443)
Replace the car
Old Nov 16, 2006 | 08:27 AM
Hondacivic90ed's Avatar
"I putted the battery"
shoulda 5 ironed it
xshytlipsx
15
Feb 6, 2009 08:11 AM
elmejor
Nov 6, 2008 07:12 AM
Si_eg6
Jul 14, 2008 02:47 PM
potential
Aug 6, 2006 07:23 PM
flatblk
Jun 9, 2005 09:41 PM
