HELP PLZ, CAR WON't Start!!! PLZ help FUSTRATED
Old Nov 12, 2006 | 02:28 PM
fabe85's Avatar
Default HELP PLZ, CAR WON't Start!!! PLZ help FUSTRATED
Ok Iam getting a check engine light. Iam trying to jump service connector (yes i have done this beforfe to my previous integras), but no-luck it acts the same way.
check engine light just stays on. also the SRS stays on.
Car used to run fine. (new dizzy, plugs, wires)
Iam not getting power to fuel pump, only way to get power is manualy running a 12v power to the grn/yellow wire at fuel pump.
engine just cranks and cranks.
How do i verifiy power to ECU
Also i have no ignition switch (was cut out by theifvin local proformance shop)
Iam just touching together all teh wire on the ignition harness to teh starter wire, to get it to crank.
i already swapped out for another realy and same problem.
Do you think its main relay.
Old Nov 12, 2006 | 07:03 PM
fabe85's Avatar
Default Re: HELP PLZ, CAR WON't Start!!! PLZ help FUSTRATED (fabe85)
any help guys
Old Nov 12, 2006 | 07:24 PM
Uncle Ben's's Avatar
Cogent Argument Enthusiast
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fabe85 &raquo;</TD></TR><TR><TD CLASS="quote">
Huh? Which relay did you replace? If it wasnt the main, then your situation sounds liek the classic main relay. I had BOTH my civic and integras main relay **** on me at the same exact time, I was pissed
86crxintheworks
Jul 13, 2006 06:48 PM
2DoorBandit
Apr 21, 2006 11:59 AM
hmnotts
Jul 27, 2005 01:51 PM
TrueNorthStar
Audio / Security / Video
13
Dec 3, 2003 01:35 PM
