Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Element question
Old Nov 12, 2006 | 11:23 AM
yooperthetank's Avatar
Default Element question
I own a 2004 element with about 33,000 miles and the maint. req'd light just came on. Also it just started to idle at about 1500 rpm. Is this normal. Are there any tsb's on this subject? Any info would be appreciated.
Old Nov 13, 2006 | 05:34 AM
Ross 2.0's Avatar
In a Junkyard near you.
the maintenance light is just triggered every 10k miles for you. (30k mile service is due: change oil, trans fluid, rotate tires, change engine and cabin air filters)
But the high idle is normal after you juststart it in cold weather if it keeps that high idle even after it has warmed up then you need to take it in and have it checked
Old Nov 13, 2006 | 06:54 AM
Default Re: (Ross 4107)
I understand the 30k service thing. I haven't got that done yet. But it still idles high after if drive it to work which is about 15 minutes. Plus I live in San Diego and the avg morning temp is right around 55 degrees this time of year. Any thoughts on the cause of the high idle? Thanks.
Old Nov 13, 2006 | 09:52 AM
Ross 2.0's Avatar
Sounds like you have some sort if I.A.C problem.
Is your check engine light on?
Old Nov 13, 2006 | 01:50 PM
1dumbscreenname's Avatar
not sure on this but sounds like an IAC (idle air control) problem, needs to be adjusted. not sure how to do it though.
Old Nov 13, 2006 | 05:53 PM
Yes the check engine light is on. What does the IAC do and can it be adjusted by a regular schmo like me?
Old Nov 13, 2006 | 06:12 PM
Ross 2.0's Avatar
it can't be adjusted. take it to autozone and get the "P (P____)" code then post it here.
Old Nov 13, 2006 | 06:29 PM
jetydosa's Avatar
25 Year Member
Default Re: (yooperthetank)
So the Check Engine Light is on, AND the Maint Required lights are on?
dustinbs144
Jan 31, 2011 07:18 AM
AccordEX1991
Mar 10, 2007 05:02 AM
19_lude_s_96
Jan 4, 2006 04:33 PM
Civicse
Feb 7, 2005 11:52 AM
Dawsonb17a
Jun 19, 2004 03:44 PM
