what type of connector
what type of connector is it its the one thats under the dizzy theres two one is like some sort of wire and the other is a white connector that connects i think like to the head of the engine what is the white connector because that wire is already in bad shape
in the picture, the red is the TW sensor for the ECU, the green is the Temperature Gauge sending unit, the light blue is the Cooling Fan Switch and the white is the Oil Pressure sending unit
green sensor is the temp gage sending unit. it will be good as new after picking up a female bullet connector fron napa. install heat shrink tubing, crimp the connector then heat up the tubing.
if you need a new plug for the tw sensor, most 2 pin plugs from any honda will fit. can be sourced from the junkyard. iat/iacv plugs will work.
From: I told you to wait in the truck in Texas, United States
TW or CTS=coolant temperature sensor
Was it running bad?
I have seen that cause hard starting/flooding before..
The ecu sees a low temperature and so it dumps fuel
as if in a cold start situation..
Was it running bad?
you can remove the pin from the connector. Just take a small screwdriver and in the plug in side of the pin push down on the tab and pull the wire out the other side. You can either cut the wire after that and resolder it or get some liquid electrical tap and patch it.
i just fixed it all i did is take out the pins and put a new wire were the old ones were but i dont think it will last for long so ill probably end up going to a junk yard and get another connector but i think thats why my car was running like **** i just fixed it and it starts quicker and responses better
Turbo EH2
Sep 29, 2006 04:03 PM
ExplicitSpeed360
Oct 24, 2005 03:04 PM
roydogg
Jun 24, 2005 12:13 AM
hondacrx90
Apr 3, 2004 08:20 PM
