abnormal reving
Old Nov 11, 2006 | 04:25 PM
jdmyoo's Avatar
Default abnormal reving
my civic esi 1.6 vtech has an annoying problem
when its cold the revs go from 1000 to 1500....up down up down. and its really annoying. when you try to pull off slowly it judders and bumps all over the place.
at the moment i gave it a full service. like everything.
has any1 had this problem
helpppp please
cheers
Ash
Eran's Avatar
HT White Ops
The problem goes away when warmed up?
Old Nov 11, 2006 | 04:28 PM
jdmyoo's Avatar
Default Re: (Eran)
no it jst comes of choke and isn't as noticable. but wen pulling away and goin threw the revs slowish it jumps the car asif i have kangaroo petrol. lol. sorry only way i could think of exsplaining it.
cheers
Old Nov 11, 2006 | 04:32 PM
Eran's Avatar
HT White Ops
Do two things:
1. Spray all your vacuum hoses (the skinny black things) down with brake/carb cleaner. If your motor revs and then dips suddenly, you've found a vacuum leak.
2. Clean your IACV:
https://honda-tech.com/zerothread?id=1575913
Old Nov 11, 2006 | 04:34 PM
jdmyoo's Avatar
Default Re: (Eran)
thanks mate..
i will try that in a sec...
cheers 4 the thread
Old Nov 11, 2006 | 05:52 PM
stealth50k's Avatar
Default Re: (hondamachash)
I know extactly what it is, the intake manifold on the back has a oval long object, which I believe is a throttle position thing. Remove it, open it up and push down the hole that has a thing in it. After that, you will never have the rev problem again.
Old Nov 11, 2006 | 05:53 PM
Eran's Avatar
HT White Ops
Default Re: (stealth50k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stealth50k &raquo;</TD></TR><TR><TD CLASS="quote">I know extactly what it is, the intake manifold on the back has a oval long object, which I believe is a throttle position thing. Remove it, open it up and push down the hole that has a thing in it. After that, you will never have the rev problem again.</TD></TR></TABLE>
What the expletive did you just say? Did you tell him to basically bypass his TPS?
No. That's a bad dog. Bad. BAD.
Old Nov 11, 2006 | 06:02 PM
spoonracer84eg's Avatar
Default Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">
No. That's a bad dog. Bad. BAD.</TD></TR></TABLE>
LMFAO
How does your ecu know how much fuel to dump in??????????????? lol
Old Nov 11, 2006 | 06:47 PM
EJgsr's Avatar
Default Re: (spoonracer84eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonracer84eg &raquo;</TD></TR><TR><TD CLASS="quote">
LMFAO
How does your ecu know how much fuel to dump in??????????????? lol</TD></TR></TABLE>
it just takes a guess.
tienzien
19
Aug 10, 2022 07:15 AM
coupedragracing
Jul 31, 2011 08:43 PM
jr000
May 19, 2008 06:06 PM
redpeppers
Jul 26, 2005 05:10 AM
Bictorious
Feb 27, 2004 09:45 PM
