why does my autometer tach jumps when blinkers or high beams are turned on?
Old Nov 10, 2006 | 06:13 PM
vladd's Avatar
Default why does my autometer tach jumps when blinkers or high beams are turned on?
i installed an autometer 5" tach and i'm having a problem with the needle jumping. when the ignition is turned to on (jumps once), blinkers blink (jumps with every blink of the arrow), or when the high beams are turned on (jumps once) the tach will jump about 400 rpm. i haven't started the car yet after installing the tach so i don't know what symptoms will appear then. does anybody have any ideas on what it could be?
Old Nov 10, 2006 | 06:42 PM
lsvtek's Avatar
Default Re: why does my autometer tach jumps when blinkers or high beams are turned on? (civicdxtyper)
Where did you wire the positive wire to?
Old Nov 11, 2006 | 05:43 PM
vladd's Avatar
Default Re: why does my autometer tach jumps when blinkers or high beams are turned on? (LSintegra4)
it's wired to the fuse box acc spot.
Old Nov 11, 2006 | 06:14 PM
Th3savinday's Avatar
it might be really closely wired to the blinker power wire and might be recieving some frequency through there.
Old Nov 11, 2006 | 06:29 PM
vladd's Avatar
Default Re: why does my autometer tach jumps when blinkers or high beams are turned on? (Th3savinday)
well, it also jumps when i turn the ignition on, or when i turn on the high beams; not just with the blinker.
Old Nov 11, 2006 | 06:38 PM
lsvtek's Avatar
Ok, when I had my Tach wired, I put the positive where the cigarrete lighter is. It was a good place I think. Take out the little pocket, you see some screws, take screws out, then get the positive wire on the cig. lighter, now get your pos. wire for your Tach and wire it. And for your negative, leave it somewere that has ground. You should be set
Modified by LSintegra4 at 12:52 AM 11/12/2006
Old Nov 11, 2006 | 07:23 PM
vladd's Avatar
how is that any better than wiring it directly to the fuse box? the only problem i can think of is that it's not run through a fuse, running the risk of frying the tach. i don't think the spot i wired the power wire to is the problem though. i wired 3 gauges, a turbo timer, and a boost controller the same way and i'm not having any problems with those.
Old Nov 11, 2006 | 11:51 PM
lsvtek's Avatar
That was my Idea, that was were I wired mine up and didnt have a problem, mayb you could try it, but I guess you think it is a bad idea. So i dont knwo what to say
Old Nov 12, 2006 | 12:19 AM
vladd's Avatar
im not saying its a bad idea; you can wire the power wire to a lot of different places. i'm saying that i don't think the power wire is the cause of this strange malfunction, since i have other stuff wired to the same spot and this is the only thing with a problem. keep those ideas coming though.
Old Nov 12, 2006 | 12:33 PM
lsvtek's Avatar
where did you wire the blue wire to? The wire that sends the RPM to the tach or however you say it.
Old Nov 12, 2006 | 01:58 PM
vladd's Avatar
it was supposedly wired to the rpm signal wire going to the gauge cluster. if it was ran to the wrong wire, what wire could cause this to happen?
Old Nov 12, 2006 | 06:01 PM
lsvtek's Avatar
I think mayb it is wired to the wrong wire. Go and tell me what color you wired it up to. And were the wire is located
Old Nov 17, 2006 | 04:32 PM
vladd's Avatar
i finally got a chance to check, and according to this page, the rpm wire is wired correctly.
Old Nov 18, 2006 | 06:13 PM
vladd's Avatar
anybody?
Old Nov 18, 2006 | 07:31 PM
Kafelatte's Avatar
which autometer tach did you get?part number would help
Old Nov 18, 2006 | 07:34 PM
vladd's Avatar
Default Re: why does my autometer tach jumps when blinkers or high beams are turned on? (kay20adc2)
po #5899 . it's the 5" phantom tach with shift light.
Old Nov 18, 2006 | 07:46 PM
Kafelatte's Avatar
white-light
blk-ground
green- rpm signa(rubber plug by driver shock tower with i blue wire)
red-12v power
Old Nov 18, 2006 | 07:48 PM
vladd's Avatar
the wiring is not the problem. i double checked everything.
Old Nov 18, 2006 | 08:15 PM
Kafelatte's Avatar
maybe you got a bad tach. hope you still have your receipt
Old Nov 18, 2006 | 09:14 PM
vladd's Avatar
just to make sure, both wires are supposed to be cut on the back of the tach, right?
Old Nov 21, 2006 | 05:42 PM
jz98ctr's Avatar
you could try temporarily wiring your new tachs input to the blue wire under the hood.
usually it's a single blue wire that goes into a little black plug and that's the only wire there.
also....you should most definitely wire your new tachs power to IGNITION not ACC
that could be the cause for the jump.
don't wire it to the fusebox...wire it into your ignition harnes....it has heavy gauge wiring that can usually support a few accessories....the fusebox output has thinner wiring that can't handle the current needs
Old Nov 21, 2006 | 05:52 PM
jz98ctr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kay20adc2 &raquo;</TD></TR><TR><TD CLASS="quote">white-light
blk-ground
red-12v power</TD></TR></TABLE>
here you go
white on AMT(autometer tach) to red/black of the car
blk to chassis ground paint-free non-shared ground
green to rpm input....blue like him and me said
red to IGNITION power
lemme explain a little bit....
your ignition switch is a 3 position switch
1 ACC
2 IGN
3 start
when you first turn the key on...only the acc wires are powered up.
then when you click once more the ignition comes on.
when you click 3 times the accessory wires drop out and only the ignition and start wires are powered until you let go and then the car stops cranking and the acc wires gets powered again.
if you have your AMT wired to acc, the voltage drops a little bit when you turn the key to ignition cuz your fuel pump and ecu and all the other **** in your ride turns on too...that's prolly where you're getting your "spike" in the rpm.
try switching the red to the ignition wire instead of accessory
doing this little switch in the wiring should solve your woes
if not, lemme know...i see wirez in my sleep
but i have seen my fair share of a honda underdash
littleblue
Nov 4, 2008 08:29 AM
ef9_civic_hatch
Jan 5, 2007 09:56 AM
Mikey3000
Sep 6, 2006 02:32 PM
team2n1hatch
Jun 18, 2003 09:37 AM
