No Resonator, Just Stock Muffler ?
Old Nov 10, 2006 | 04:33 PM
sleeper101's Avatar
Default No Resonator, Just Stock Muffler ?
As the title says, is it gonna be a good exhaust set up on stock motor ?
How loud would it be? ( Compare to "coffee-can" Ebay cat-back)
Old Nov 10, 2006 | 04:39 PM
Eran's Avatar
HT White Ops
Without the resonator, it'd probably be a bit rhaspy.
Old Nov 10, 2006 | 06:28 PM
BudgetBalla's Avatar
Default Re: (Eran)
I have the stock exhaust with stock cat. I had the resonator chopped off and a shop welded in a straight pipe. Tiny bit of rasp at take off, sounds very sporty to me
Old Nov 10, 2006 | 08:09 PM
jpciii's Avatar
if you are talking about a mostly stock setup only without a resonator,... then it will be raspy, bumble-bee, weed-eater... but not loud. You'll hear the rasp because that is the only noise that the exhaust willl make... no rumble or vrooom sound only rasp at certain rpms.
Old Nov 11, 2006 | 12:35 AM
sleeper101's Avatar
Default Re: (Eran)
So, If this setup is :
Stock Header,
Test-Pipe-Cat,
No Resonator,
Stock Muffler
Is it gonna be somewhat OK? ( not ricey / cheap ebay exhaust noise) ?
Old Nov 11, 2006 | 01:20 AM
wudini's Avatar
Default Re: (sleeper101)
put your cat back on. you dont even have an exhaust system and you put a test pipe in place of your cat??
as for the exhaust note, it will sound raspy. i've heard it done to a 4 banger before. it will sound rice without the bling.
Old Nov 11, 2006 | 05:37 AM
Dwight Schrute's Avatar
Default Re: (wudini)
i have a 92 dx with a stock d15b7, and a oem teg type r muffler with custom 2.25" piping, bseries cat, no res, and it sounds great. slight rasp when my car isnt warmed up, after that it sounds like an ex-mag.
Old Nov 11, 2006 | 04:41 PM
sleeper101's Avatar
Actually, this is sort of Low-Budget mods
and, on this stock EX motor,
Replaced the OEM Cat with a (straight)Test Pipe,
No Resonator,
Stock Muffler.
Practical comments are welcomed
Old Nov 11, 2006 | 04:54 PM
trrbl1bmx's Avatar
Just curious as to why you type in bold... as if we're not gonna read it all? But if I were you, and you want to have a nice tone, but with a low cost. Go to you local advance or auto zone and buy the $25-$35 Magnaflow or Flowmaster muffler, single in/single out and put that in place of your stock muffler. You'll notice a little more useable power/torque in low-mid rpm range. And it will sound cool. Best part is you can paint it black and put an OEM tip on it, and you'll really be a sleeper! This same setup is on an 11sec EG (after market piping of course) It must be good, because the guy sold me his BuddyClub Spec II in place of it!
Old Nov 11, 2006 | 05:00 PM
Eran's Avatar
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeper101 &raquo;</TD></TR><TR><TD CLASS="quote"> Actually, this is sort of Low-Budget mods
No Resonator,
Stock Muffler.
All of that is going to net you less than your stock advertised hp. You will lose power with your "low-budget mods"
Old Nov 15, 2006 | 04:32 PM
sleeper101's Avatar
Default Re: (drewthomas14)
Thanks guys
k_lude
Jun 20, 2008 09:44 AM
mugenpowered
14
Apr 18, 2006 08:48 PM
ATX96coupe
Oct 9, 2004 08:30 PM
yoda888
Jan 8, 2004 10:25 PM
PatrickGSR94
Aug 31, 2003 04:20 PM
