more aggressive cams = higher compression???
as of now im running on sk2 stg2 cams, but i want something abit more aggressive...
theres a set of toda vtec killer cams and a set of the sk2 stg 3 cams going for pretty cheap and im pretty sure i need higher compression to even consider utilizing the power these things put out...but im not sure if thats the case...
as of now i have a fully built head, but a stock block....
98 jdm itr motor
head consists of port n polish, 5 angle valve job, titanium springs and retainers, ferrea valves, sk2 stg 2 cams, cam gears....
so my question is do i need to upgrade the block to a higher compression in order to run the cams mentioned above? or is the stock compression on the itr motor sufficient enough...thanks for your help guys...
98 jdm itr motor
toda VTEC killers - race only, not a good idea for street. literally no VTEC function, they are locked into high profile at all times.
Go with the Skunk2 Pro2 and a one layer headgasket. Along with some tuning.
ZenkaiRacer
Sep 29, 2006 11:08 PM
digital sol
Jan 4, 2006 11:04 AM
