Hood spacers?
Old Nov 10, 2006 | 11:43 AM
TunerShark's Avatar
Default Hood spacers?
so can you just put washers under the hinge to make it stick up more? is that all you people do to space it out?, or am i missing someting? i tried to search but no luck.
thanks
Old Nov 10, 2006 | 12:02 PM
platinumx6's Avatar
You COULD do that, but why exactly do u want hood spacers ??
Old Nov 10, 2006 | 12:13 PM
spork motorsports's Avatar
* B A N N E D *
Default Re: (platinumx6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinumx6 &raquo;</TD></TR><TR><TD CLASS="quote">You COULD do that, but why exactly do u want hood spacers ??</TD></TR></TABLE>
platinumx6 ur a dumbfuck
op
yes and if you want it higer get longer bolts............done
search been covered millons of times
Modified by spork motorsports at 1:38 PM 11/10/2006
Old Nov 10, 2006 | 12:18 PM
TunerShark's Avatar
Default Re: (spork motorsports)
yeah i tried, says no results, its either the search function on this board sucks, or im a n3wb at it, anyways, do i need to get longer bolts, or can i just get rubber washers to space it out?
thanks
Old Nov 10, 2006 | 12:20 PM
platinumx6's Avatar
and im a dumbfuck because....?
Why cant you just be polite, I've apologized to you for me being nub, and for saying anything.
op
unless you need the extra clearance, i wouldnt do it. It looks tacky.
Old Nov 10, 2006 | 12:23 PM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spork motorsports &raquo;</TD></TR><TR><TD CLASS="quote">ur a dumbfuck
op
search been covered millons of times </TD></TR></TABLE>
Ouch man, that's some harsh ****....
Sadly people like this must be apologized for... certain things, big radiators (never seen a radiator cause this but I'm sure it can ), especially the H22's w/ certain mount set, etc. where the hood wont close all the way due to clearance you can fix by using spacers, then the hood "closes" further up so you won't have that problem...it's good for if your hood won't close by like 1/2 an inch due to an H22 or something...
Old Nov 10, 2006 | 12:27 PM
platinumx6's Avatar
Default Re: (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">
Sadly people like this must be apologized for... certain things, big radiators (never seen a radiator cause this but I'm sure it can ), especially the H22's w/ certain mount set, etc. where the hood wont close all the way due to clearance you can fix by using spacers, then the hood "closes" further up so you won't have that problem...it's good for if your hood won't close by like 1/2 an inch due to an H22 or something... </TD></TR></TABLE>
yup, exactly. Now read my post that i wrote BEFORE you wrote yours.
i wanted HIS responce to wanting them before i said something.
Old Nov 10, 2006 | 12:28 PM
Syndacate's Avatar
Oh...sorry, I didn't even see it. I pressed the "reply" button before you posted that...
Old Nov 10, 2006 | 12:29 PM
platinumx6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">Oh...sorry, I didn't even see it. I pressed the "reply" button before you posted that...</TD></TR></TABLE>
np bro. I wish spork would just drop our beef...
* B A N N E D *
Default Re: (TunerShark)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TunerShark &raquo;</TD></TR><TR><TD CLASS="quote">yeah i tried, says no results, its either the search function on this board sucks, or im a n3wb at it, anyways, do i need to get longer bolts, or can i just get rubber washers to space it out?
thanks</TD></TR></TABLE>
its cool, depends how far you want to go, i would just go in your random bolts box and get bolts to a thermostat cover/housing or something and go from there, dont need to be much longer, if you need bolts give me like 5 bucks for shipping and ill send some over to ya,
dominicanvtec
Jan 21, 2008 04:10 PM
wowowee
Feb 27, 2007 05:27 PM
b16greenmachine
14
Dec 6, 2006 11:16 AM
mesmvc2
Jan 3, 2006 06:20 PM
JaY-R
Apr 19, 2004 04:37 PM
