GM Syncro + LSD
Old Nov 10, 2006 | 09:56 AM
garyc17's Avatar
Default GM Syncro + LSD
Can I use GM Syncromesh Friction Modified with a clutch pack 1.5 way LSD? Or should I use Redline MT-90 or MTL?
Old Nov 10, 2006 | 10:18 AM
Desired_Speeds's Avatar
is your tranny having problems like grinding?
Old Nov 10, 2006 | 10:54 AM
DontBlink's Avatar
Default Re: (Desired_Speeds)
i use it with my KAAZ lsd. 2 years and no issues yet.
Old Nov 10, 2006 | 07:34 PM
garyc17's Avatar
My tranny ain't grinding. I just have a sticky 2nd gear mostly when I downshift from 3rd.
Old Nov 10, 2006 | 07:35 PM
garyc17's Avatar
Default Re: (DontBlink)
Is KAAZ LSD a clutch pack type?
Old Nov 11, 2006 | 03:10 AM
RagingAngel's Avatar
Default Re: (garyc17)
yes
Old Nov 11, 2006 | 03:54 AM
RTW DC2R's Avatar
I use it on my stock LSD but I dont know if thats a "clutch type" or not
<<<doesnt know jack about LSDs y0
Old Nov 11, 2006 | 05:10 AM
Default Re: (RTW DC2R)
OEM ITR is tEh HELICOPTOR (helical/gear) type yO!
Old Nov 11, 2006 | 05:17 AM
walker111's Avatar
Default Re: GM Syncro + LSD (garyc17)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by garyc17 &raquo;</TD></TR><TR><TD CLASS="quote">Can I use GM Syncromesh Friction Modified with a clutch pack 1.5 way LSD? </TD></TR></TABLE>
Yes
Old Nov 11, 2006 | 08:19 AM
sleeprhatch's Avatar
Default Re: GM Syncro + LSD (walker111)
Ive been using it for the paste 4 years. stuff is great.
Old Nov 11, 2006 | 08:49 PM
garyc17's Avatar
Is it normal for a clutch pack LSD to shudder violently on slow speed turns? Mine shudders and feedbacks like crazy in the morning when I make turns. After a few more turns at the lights, it stops shuddering. It also happens after I park the car for an extended period of time. I am using Motul 75W90 tranny fluid. It didn't shudder in the past with another fluid.
Old Nov 12, 2006 | 10:31 AM
DontBlink's Avatar
mine does the same thing, once it warms up its fine. my diff is 100% locking. i know with the KAAZ you can set the clutch plates A-B-A-B for 100% or if you want it less set them at A-B-B-A and they will slip a little(i forget the % it takes the locking down to)and it wont be jerky going around corners.
i never used any of the KAAZ oil or a heavier weight oil in my transmission because i was worried about synocro damage, but the synocrmesh seems to be working really well.
Old Nov 13, 2006 | 07:56 AM
walker111's Avatar
Might be time for a rebuild. IMO you should take that diff out and replace it with a stock one.
Old Nov 14, 2006 | 12:20 AM
garyc17's Avatar
Why do you say I should replace it with a stock one?
Old Nov 14, 2006 | 12:33 AM
garyc17's Avatar
Default Re: GM Syncro + LSD (DontBlink)
Its gonna be a LSD rebuild or a stock one goes in. I get this rough sound from the tranny when my foot is off the gas in any gear slowing down. Seems like the clutch pack might be gone.
Old Nov 14, 2006 | 06:13 AM
Mugen Mike's Avatar
Do we really have to go over this all over again?
https://honda-tech.com/zerothread?id=1707316
https://honda-tech.com/zerothread?id=1718638
Old Nov 14, 2006 | 06:57 AM
walker111's Avatar
Default Re: GM Syncro + LSD (Mugen Mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugen Mike &raquo;</TD></TR><TR><TD CLASS="quote">Do we really have to go over this all over again?
https://honda-tech.com/zerothread?id=1718638</TD></TR></TABLE>
This is why I say find a stock one. You obviosly are not the person to have/understand/deal with a clutchpack diff.
Old Nov 14, 2006 | 07:24 AM
P1_Variable's Avatar
Default Re: GM Syncro + LSD (sleeprhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote"> Ive been using it for the paste 4 years. stuff is great. </TD></TR></TABLE>
mmmm paste.. I use Syncromesh in both my cars.
Old Nov 14, 2006 | 08:25 AM
garyc17's Avatar
Okay lets wrap this up... I got no dough for a rebuild. I want to change my fluid. Redline MT-90, Motul 75W90 or GM Syncromesh with Friction Modifier?
Old Nov 14, 2006 | 08:28 AM
walker111's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by garyc17 &raquo;</TD></TR><TR><TD CLASS="quote">Okay lets wrap this up... I got no dough for a rebuild. I want to change my fluid. Redline MT-90, Motul 75W90 or GM Syncromesh with Friction Modifier?</TD></TR></TABLE>
The point we are making is that you have asked this question numerous times and still came back and asked the same question.
Put synchromesh in hopefully it works and this will be the last thread discussing this tired topic
Old Nov 14, 2006 | 08:30 AM
EG6-DC2's Avatar
I don't think anyone said a rebuild of the entire tranny. I think they said to change out the Diff to go back to a stock one. I doesn't sound like you use the car in any way that it would require an upgrade to a clutch type diff.
I also don't think your going to find any miracle tranny fluid to stop whatever noises/feelings you are getting. Just put in some Syncromesh w/ FM if your heart desires and deal with your diff or change your diff out liek others have said...
Old Nov 14, 2006 | 08:31 AM
EG6-DC2's Avatar
Default Re: GM Syncro + LSD (EG6-DC2)
Damnit Jim, you beat me to the last word!
Old Nov 15, 2006 | 09:35 PM
garyc17's Avatar
Points noted. Thank you everyone for the inputs.
Baron55
Aug 6, 2006 01:53 PM
alexdog69
Oct 5, 2005 08:09 AM
KFBhonda
Mar 4, 2005 02:48 PM
112480
May 1, 2003 06:45 PM
JDM_JON
Jan 7, 2003 11:20 AM
