can you tell if my timing is off (pics)
Old Nov 10, 2006 | 09:53 AM
stocker2shocker91's Avatar
I requested a short story for a title.
Default can you tell if my timing is off (pics)
can you take a look at these to help me figure out if my timing if in fact off. this is the last thing i can think of to get this running. here are some symtoms....It idles rough and backfires like crazy. compression is good and i changed wires and plugs. but here are the pics
Old Nov 10, 2006 | 10:27 AM
__oversea's Avatar
Default Re: can you tell if my timing is off (stocker2shocker91)
looks like its off. both arrow has to be face same direction.
Old Nov 10, 2006 | 10:43 AM
projectTeG's Avatar
need better pics and the cams gears arent the only think that need to be lined up, check to make sure the crank is at tdc. the belt has slack in it to.... also whens the last time you changed you cap and rotor?
Old Nov 10, 2006 | 10:46 AM
Padawan's Avatar
Darth ModerVader
The pictures could be better, but I agree that it looks as if the timing is off a bit.
Old Nov 10, 2006 | 11:27 AM
BLacK FirE's Avatar
Default Re: can you tell if my timing is off (Padawan)
can't tell anything from those pics. Get a small ruler and use that to line up the 4 lines on the cam gears and as project said, make sure the crank is also lined up at tdc.
Old Nov 10, 2006 | 12:18 PM
Honda Hick's Avatar
Default Re: can you tell if my timing is off (BLacK FirE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLacK FirE &raquo;</TD></TR><TR><TD CLASS="quote">can't tell anything from those pics. Get a small ruler and use that to line up the 4 lines on the cam gears and as project said, make sure the crank is also lined up at tdc. </TD></TR></TABLE>
Exactly . Those 2 lines might be touching, but the other 2 on the other side of the gears need to be in line also.
Old Nov 10, 2006 | 03:59 PM
LordAphotic's Avatar
its off by as much as two teeth... look at the arrows. they are supposed to be parrallel to one another.
Old Nov 10, 2006 | 04:21 PM
projectTeG's Avatar
move exhaust cam back(firewall) on tooth and move the intake cam one tooth towards the front.
qfast817's Avatar
Default Re: (LordAphotic)
looks off like a tooth and the belts loose.
Old Nov 10, 2006 | 05:47 PM
Sumslapper's Avatar
Year 3030
Default Re: (qfast817)
daaamn the inside of yur head looks nasty. And yes your timing is off. better fix it before you break somethin
Old Nov 10, 2006 | 07:37 PM
RJonathan's Avatar
I believe it looks off because there's alot of slack at that part, try using a 14mm and moving the exhaust cam gear towards the radiator and intake cam gear towards the firewall to take away the slack and retake the pictures.
Old Nov 10, 2006 | 11:32 PM
DB1_559's Avatar
lock both cams up there a hole so you can see if its off i think its easier that way
Old Nov 11, 2006 | 08:27 AM
rdssk8rcs1's Avatar
wow is the mark on the crank off as well?
Old Nov 11, 2006 | 10:31 AM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: can you tell if my timing is off (jdmboi86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmboi86 &raquo;</TD></TR><TR><TD CLASS="quote">lock both cams up there a hole so you can see if its off i think its easier that way</TD></TR></TABLE>
Do that to line the cams up TDC, or to even see if they Will,
If they won't, then they're definitely off.
The whole is in the cam cap, and will be on the camshaft while at TDC.
Old Nov 11, 2006 | 10:33 AM
RaceMyGhost's Avatar
Default Re: can you tell if my timing is off (CleanLikeJdm)
looks like you also have some sludge build up in there.
Old Nov 11, 2006 | 02:15 PM
POE's Avatar
POE
haha ^ and yes boye you are way off. Make sure those arrow's are facing straight up, and make sure your crank position is lined up down below also.
Old Nov 11, 2006 | 04:30 PM
92integraVTECgsr's Avatar
cams look off..
also u need the crank pulley lined up too.
Old Nov 11, 2006 | 08:18 PM
BLacK FirE's Avatar
Default Re: (POE)
As I've already stated, you go by the 4 ticks on the cams, not the arrows. The arrows are just an estimate and when everything is at TDC they're actually not 90 degrees staight up.
Old Nov 11, 2006 | 08:25 PM
Dogginator's Avatar
Daisy... Daisy...
I like to extend a piece of string across the gears to make sure that the marks are aligned. From the pictures, it looks like your gears are off.
Old Nov 14, 2006 | 10:12 AM
schoedog2323's Avatar
Default Re: can you tell if my timing is off (Dogginator)
timing is deff off plus u need to tighten that belt up or your timing is going to be off again in the near future
DeCoY
Jul 21, 2017 10:15 PM
SneezinCD5
82
Oct 4, 2011 06:07 AM
B16-CRX
Apr 25, 2011 06:27 PM
stocker2shocker91
Nov 10, 2006 10:18 AM
