Help a cripple with his clutch pedal problem
Old Nov 10, 2006 | 07:05 AM
CHOWBOX's Avatar
Default Help a cripple with his clutch pedal problem
First off let me tell you that I am a left below the knee amputee. My ankle does not bend unless extreme force is placed on it. I have absolutely no problems shifting my S2k. My 98 LS is a different story.
I can’t seem to get the pedal fully down to engage the clutch. It makes the final pull into any gear hard/ stick whatever you want to say. It has to do with the angle of the dash. If the floor was an inch or two lower this problem wouldn’t exist. My friends have driven the car & there is nothing wrong. This is the first time I have had this problem with a manual transmission & just bought this thing as my winter beater so I’m keeping it.
My question is how to remedy the problem. Do those pedal covers make the pedals any thicker? I think I only need ¾” thicker clutch pedal to fix it. Anyone have any pics of pedals or how these things attach, etc. or any crappy ones laying in the junk drawer I can pay you a couple bucks to send me. I only want the clutch pedal.
Let me know
Thanks
Old Nov 10, 2006 | 07:10 AM
Racermech's Avatar
Default Re: Help a cripple with his clutch pedal problem (CHOWBOX)
What about using a piece of wood or steel to build up the pedal??
Also you could look into the omni clutch MC, it reduces the throw, but I am not sure how much extra preasure it does require.
Old Nov 10, 2006 | 07:23 AM
CHOWBOX's Avatar
Default Re: Help a cripple with his clutch pedal problem (Racermech)
I like the idea of a shorter throw, but don't really want to invest that much money into it. the extra force isn't a big deal.
not sure how to attach wood or metal that would hold up over time. I'd be pissed if I had to putz with it every week
Old Nov 10, 2006 | 07:26 AM
Padawan's Avatar
Darth ModerVader
The aftermarket pedals generally do not add much thickness to the pedal, but you may find some that are slightly thicker. Depending upon how much you'd like to spend, you have a couple of other options. Of course, there are the adjustable pedal extenders, which are available from several sources, and you should be able to get an individual clutch model since you don't require the whole set. You may also want to consider having an extension welded or bolted directly on (perhaps even something you could do yourself), which would allow you to tailor the pedal precisely to your specific needs, and which wouldn't be all that costly.
Old Nov 10, 2006 | 07:28 AM
Racermech's Avatar
You could get a 2"x2"x3/4" block of steel. Drill and countersink a couple of holes. You can either drill it dirctley to the pedal, or if you run the holes on the outside of the pedal then you can make a backing plate to tighten it down to the pedal.
Old Nov 10, 2006 | 07:33 AM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Racermech &raquo;</TD></TR><TR><TD CLASS="quote">You could get a 2"x2"x3/4" block of steel. Drill and countersink a couple of holes. You can either drill it dirctley to the pedal, or if you run the holes on the outside of the pedal then you can make a backing plate to tighten it down to the pedal.</TD></TR></TABLE>
A good suggestion, though I'd only use steel if I were going to be welding the extension to the pedal. Aluminium would be easier to work with if you were going to be drilling through it to mount with bolts, and would also make it much easier to machine some texture into the contact area to prevent slipping. Depending upon how much time you wanted to put into it, it would turn out quite well and be a fun project.
Old Nov 10, 2006 | 07:34 AM
CHOWBOX's Avatar
Default Re: Help a cripple with his clutch pedal problem (Padawan)
thanks
how do aftermarket pedals attach? I could space it out with extra nuts if they bolt on.
Old Nov 10, 2006 | 07:36 AM
CHOWBOX's Avatar
thanks for the ideas. I googled the problem & found these
http://www.creativecontrolsinc...x.htm
problem is they want like $100 & I only need 3/4" not 6"
Old Nov 10, 2006 | 07:37 AM
skunked's Avatar
what year is the car?
You can adjust the pedal height at which the pressure plate engages/disengages
Old Nov 10, 2006 | 07:41 AM
CHOWBOX's Avatar
Default Re: Help a cripple with his clutch pedal problem (skunked)
98, oh please tell me more
Old Nov 10, 2006 | 07:42 AM
Racermech's Avatar
I think in steel as I work in a structural steel shop. I would be a pretty cool project!
Old Nov 10, 2006 | 07:49 AM
skunked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CHOWBOX &raquo;</TD></TR><TR><TD CLASS="quote">98, oh please tell me more</TD></TR></TABLE>
adjust the clutch master cylinder so the rod is longer. This will allow the clutch to engage/disengage quicker with less pedal travel.
Old Nov 10, 2006 | 07:55 AM
CHOWBOX's Avatar
I run a service station. I'll have one of my techs look at it after lunch.
I knew you guys would know what to do.
Old Nov 10, 2006 | 07:56 AM
skunked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CHOWBOX &raquo;</TD></TR><TR><TD CLASS="quote">I run a service station. I'll have one of my techs look at it after lunch.
I knew you guys would know what to do.</TD></TR></TABLE>
Old Nov 14, 2006 | 10:15 AM
Racermech's Avatar
Any updates, did you get anything adjusted?
Old Nov 14, 2006 | 11:19 AM
PhatTeg86's Avatar
sounds like a good challenge for a welder )
Keep us all posted
globy123
Dec 20, 2015 02:38 PM
egekreject
Mar 12, 2007 06:44 AM
taytay333
Nov 21, 2001 12:58 PM
Charged R
Oct 3, 2001 07:53 PM
