D17 crank in D16
Old Nov 10, 2006 | 12:41 AM
speedracer209's Avatar
Default D17 crank in D16
I got this idea from the zeal compression calculator it gave me a compression ration in the 11's. my question is it even possiable to put a D17 crank into the D16 as a bolt on affair or would I need to make changes to the block has anyone done this before?
Old Nov 10, 2006 | 02:01 AM
R1Motorsports.com's Avatar
Default Re: D17 crank in D16 (speedracer209)
I think it's been talked about a lot over at http://D-series.org
Try doing a search over there, you should find what your looking for.
Old Nov 11, 2006 | 07:44 PM
stealth50k's Avatar
Default Re: D17 crank in D16 (R1Motorsports.com)
Possible, but I never seen it done before, so I don't know.
Old Nov 11, 2006 | 09:08 PM
spork motorsports's Avatar
* B A N N E D *
Default Re: D17 crank in D16 (stealth50k)
i think it would basically make it a d17 with 16 pistons
valves meet piston, piston meet valves
* B A N N E D *
Default Re: D17 crank in D16 (spork motorsports)
be sure to CLAY the motor before you run it
Old Nov 11, 2006 | 09:13 PM
Jim Truett's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedracer209 &raquo;</TD></TR><TR><TD CLASS="quote">my question is it even possiable to put a D17 crank into the D16 as a bolt on affair or would I need to make changes to the block has anyone done this before?</TD></TR></TABLE>
Yes, it is possible, in fact, that is what I am running right now. You need to notch the block and main girdle for the rod swing. You will need to carry over the crank/rods/pistons/oil pump from the D17, or have custom pistons and rods made if you are looking for more than 280whp. I am running right at 260whp at 11 psi right now, on stock rods with polished beams, and stock PLR pistons .020" over. You will also need to run a b16 crank pulley, or bore out the stock D16 crank pulley to match the D17 crank snout. If you are using a D16Z6 block you will need to modify a D16Y8 rear main seal housing to fit. If you are using a D16Y8 block, you will need to drill the oil pump for the dipstick. Either way, you will need a Y6 or Y8 oil pan.
avaldez
Mar 16, 2010 07:53 PM
the jdmchop
Oct 21, 2005 07:28 AM
rasinhell
Aug 27, 2005 05:46 AM
yellow_jacket
20
Jan 27, 2004 07:37 PM
