help: car doesn't start sometimes
i'll try to keep this easy ti understand... basicly, my car starts and is warmed up, then i turn it off at the gas station then i try to start it again it doesn't start... the ECU just keeps on clicking when i crank... and this resets all my clock and radio stations and resets my ECU. I looked into the battery but its fine... still charging, and this only happen twice and both times is when i turn off the car after its warm... can someone give me a hand... engine is stock d16y7 with stock ECU..
someone told me about my main relay but i am not sure what that means hahaha... thanks in advance..
bad ground perhaps. check your negative battery cable. and also your other grounds, specifically the one by the starter that grounds to the tranny.
i think once your main relay is gone its gone, not starting sometimes... correct me if im wrong though.
smbignick
Aug 18, 2013 01:47 PM
