2.4 conversion help
i have a h22 right now. i want to convert/rebuild it to a 2.4 all motor but i'm not sure how to do so. do i just buy new pistons like wiseco, je , srp, or cp. which one is better?
i was thinking about the je on nopi.com:
Piston Set of 4 - 2.2L 4cyl DOHC VTEC H22A1 - Bore: 87mm / 3.425in - Rings: 1.2/1.2/2.8mm - Oversize: STD - Stroke: 3.571 - Rod Length: 5.63 - Compression Distance: 1.22 - Head CC: 53.8 - Compression Ratio: 11.5:1 - Dome Volume: 9.8 - Weight: 348grams - Not designed for use with turbo or nitrous - must sleeve block - Use with piston ring set 135+3025 $472
after that, do i just take it to a shop to port the cylinders and put them in?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rosko »</TD></TR><TR><TD CLASS="quote">mother of god....</TD></TR></TABLE>
LOL!!!!
just shave a couple inches off the top of the piston that should give you the added displacement lol
LOL!!!!
To get to 2.4 you'll have to change a combination of bore, stroke, and rod length.
Not that big of a deal, but I think its just a little over your head till you do some more research. Theres lots of good info on here so go use it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rosko »</TD></TR><TR><TD CLASS="quote">To get to 2.4 you'll have to change a combination of bore, stroke, and rod length.
Not that big of a deal, but I think its just a little over your head till you do some more research. Theres lots of good info on here so go use it.</TD></TR></TABLE>
alterdcreations
28
Apr 30, 2009 08:06 AM
