need to reset ECU after new 02 sensor install?
is it necessary? my old downstream one was throwing a CEL, and i was getting horrible mileage, so i replaced it with a DENSO one, and i torqued it to about 30 ft/ibs and used the liquid stuff it came with to put on the threads, and i still have a feeling im getting bad mileage. so is it because i need to reset my ECU or what?
thanks
thanks
ok, i used some gumout fuel system cleaner now when i filled up my tank to the top, so well see how this goes.
remove negative terminal of battery.
count to 10 slowly.
reconnect battery terminal.
Start car and let idle for 15 minutes.
Switch off car.
done.
If you're OBD2 you will have to drive the car for a couple days to clear the readynesss flags to be emissions legit.
count to 10 slowly.
Switch off car.
done.
egvtec
Sep 7, 2010 08:02 PM
TunerShark
Nov 18, 2006 01:21 PM
undertheradar
10
Dec 4, 2004 04:04 AM
