Help with D serie Tranny wap
Old Nov 9, 2006 | 06:36 PM
The Flying Dutchmen's Avatar
Default Help with D serie Tranny wap
Did the search, and i've taken mine off before, but what size/type of punch do you need for the b*tch pin on the shift linkage. i always took it off down by the shifter, but they cut it on the one i bought. THanks alot
Old Nov 9, 2006 | 06:42 PM
jllong95's Avatar
about a 1/4 in. flat top punch
Old Nov 9, 2006 | 07:27 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: (jllong95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jllong95 &raquo;</TD></TR><TR><TD CLASS="quote">about a 1/4 in. flat top punch</TD></TR></TABLE>
Is there some other way to get that thing out?
Old Nov 9, 2006 | 09:25 PM
HomicidalHatchBack's Avatar
8mm non tapered pin punch its like 5 bucks or less at a hardware store thats what i just used when i replaced my tranny worked fine
Old Nov 9, 2006 | 09:27 PM
Default Re: (ek forever guy)
some place made a c clamp like thing kinda like a ball joint remover/installer but the pin punch is cheaper and works fine
Old Nov 9, 2006 | 10:36 PM
sol2hatch's Avatar
Default Re: (HomicidalHatchBack)
BFH+right size anything (ie Bolt, punch, whatever)+a little lubricant=not so bitch pin afterall
Old Nov 13, 2006 | 01:23 PM
thanks guys, Sears was close and AAP failed again, but found a good screw and got it out, in (with the shift linkage upside down), out, and back in again. Human ingenuity wins, but yes it is still the bitch pin
Old Nov 13, 2006 | 01:27 PM
Timberland237's Avatar
i made one buy taking a long punch like 12" and grinding the end taper so that i can take it out from the top with a hammer no hassle at all comes right out
Old Nov 13, 2006 | 02:47 PM
t0p_sh0tta's Avatar
Default Re: (Timberland237)
Too much work.
I have a long ~24" 1/4 extension that pops that bitch right out from the top.
Old Nov 14, 2006 | 12:34 PM
teal_dx's Avatar
Default Re: (t0p_sh0tta)
manual says 8mm punch to use on the "bitch pin"
thundernutz
Sep 27, 2009 04:22 AM
ReactioN
Jun 3, 2008 11:31 AM
Nicaraguense13
14
Aug 30, 2006 10:44 AM
stegon78
Jun 24, 2005 08:46 AM
jondancer
10
Apr 15, 2003 01:05 PM
