the PIN!!!!
Re: the PIN!!!! (turbociviccoupe)
with what and i have the tranny out im building a motor thats why (someone cut the linkage instead of taking it out
Re: the PIN!!!! (Nicaraguense13)
You need to hit it with something that's the same size to keep the head from mushrooming.
Sounds like it's too late for that, so keep beating the **** out of it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nicaraguense13 »</TD></TR><TR><TD CLASS="quote">i heard their is a certain size puncher that fits???? and from any of the two side i can hit it?? </TD></TR></TABLE>
from the bottom of the tranny.
Location: Where the Hondas come out at nite, Ca, united states
ummm use a 1/4" or 8mm punch
r u tryin to put in a short shifter...cuz u dont need to do all that ...it makes it easier ...but possible with out removing it
Re: the PIN!!!! (sergio461)
8mm roll pin punch is the right tool, but the ac compressor bracket bolt with the point works perfect if your in a jam, thats what I always use.
be professional
8mm or 1/4" punch for roll pin/spring pin. Or this: http://www.matcotools.com/Cata...51164
An air hammer also works.
HT Order of Merit
Re: the PIN!!!! (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18cKoupe »</TD></TR><TR><TD CLASS="quote">8mm roll pin punch is the right tool, but the ac compressor bracket bolt with the point works perfect if your in a jam, thats what I always use.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">8mm or 1/4" punch for roll pin/spring pin. Or this: http://www.matcotools.com/Cata...51164
An air hammer also works.</TD></TR></TABLE>
a large sledge hammer starting out makes it easier too.
just make sure you line it up perfectly....and that you aren't banging on your linkage like some sort of animal.
I took a 3/16 nut driver, broke the head apart, and smashed the handle till the shaft came out. When I was done, I had about a 8mm punch and it came out really easy.
So in otherwords, get an 8mm punch lol
The Flying Dutchmen
11-14-2006 12:34 PM
quicksol95
22
10-10-2004 01:09 PM
jondancer
10
04-15-2003 01:05 PM
