99 si low idel
Old Nov 9, 2006 | 06:32 PM
mugenDA9 lover's Avatar
Default 99 si low idel
my friend has a 99 civic si with intake, greddy sp1 cat back, nology wires, denso plugs ans some other stuff. the car was running fine and now it just wants to idel at 2-300 rpm and almost shuts itself off. we cheched the plugs and all the grounds. we even tried resetting the ecu. the car isnt throwing any cels and we cleaned the idel screw etc. if you can help i would appericate it thanks
Old Nov 9, 2006 | 08:05 PM
VRD^sam's Avatar
Default Re: 99 si low idel (mugenDA9 lover)
umm...
Old Nov 9, 2006 | 08:08 PM
BuiltforSin's Avatar
also interested in answer..
BLUE EH3's Avatar
Help we my pennies
Default Re: (mugenej8power)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugenej8power &raquo;</TD></TR><TR><TD CLASS="quote">also interested in answer..</TD></TR></TABLE>me3
Old Nov 10, 2006 | 01:51 PM
no one knows??
Old Nov 11, 2006 | 09:24 AM
bump for answer
Old Nov 11, 2006 | 10:08 AM
JonSilva's Avatar
Old Nov 11, 2006 | 10:26 AM
k20EP3's Avatar
Default Re: (JonSilva)
The only thing i could think of is maybe a dirty fuel filter or a bad fuel pump or something to do with the timing...you said you cleaned the idle screw so its not that. I would check a few of those things and if you cant find the problem i sugest you take it to a certified honda shop and have them take a look at it. good luck man
Old Nov 11, 2006 | 12:32 PM
civic_si_jones's Avatar
Default Re: (k20EP3)
mine is doing the same thing... I changed the fuel filter & air filter. I think it could be the ignition components like the plugs, cap & rotor, and wires.
Old Nov 12, 2006 | 03:49 PM
we replaced the fuel filter and checked the pumo and everything is good car still has low idel tho
pimpchickpcfl
11
May 10, 2009 11:00 AM
vtecnique69
Oct 15, 2007 12:09 PM
Guineapig
Apr 17, 2007 07:28 PM
kmodee23
11
Feb 1, 2006 07:10 PM
Anthonyl469
Jun 17, 2004 09:58 PM
