Amp fuse keeps blowing, 00 Si EM1
Old Nov 9, 2006 | 03:42 PM
hondab1015's Avatar
Default Alternator fuse keeps blowing, 00 Si EM1
Alternator fuse, not amp fuse.
For some reason my under dash #15 fuse, rated 7.5 amps, keeps blowing. I have replaced the ELD(electrical load detector) in the under hood fuse box, I have replaced the alternator. It will blow not 5 seconds after you strat driving down the road. Everytime......
Any ideas?
Old Nov 9, 2006 | 07:32 PM
hondab1015's Avatar
No one else have this happen?
Old Nov 9, 2006 | 07:49 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: (hondab1015)
Check your grounds.
Old Nov 10, 2006 | 03:42 AM
EE_Chris's Avatar
Default Re: (ek forever guy)
...and check for shorts to ground in that particular power wire.
Old Nov 10, 2006 | 05:30 AM
EM199dcs's Avatar
Default Re: Alternator fuse keeps blowing, 00 Si EM1 (hondab1015)
I had something like this but it was the wires from my si spoiler they were exposed so the neg. touched the pos. and blew a fuse which controled my horn, and brake lights. Make sure there is no bare wire.
Old Nov 10, 2006 | 05:56 AM
blaze the chemi's Avatar
#15 is the Alternator fuse. The ELD unit, Gauge Assembly and PGM-FI are in this line. It looks like too that the Integrated Control Unit is connectred to it as well. These sensors in then connected to fuse 15 as well:
Secondary O2
EVAP bypass solenoid valve
EVAP Canister vent shut valve
EVAP Purge control solenoid valve
VSS
Primary O2
Alternator
These are the things to check. Hope you have a Helms.
Old Nov 10, 2006 | 05:59 AM
f20bej1's Avatar
Default Re: Alternator fuse keeps blowing, 00 Si EM1 (blaze the chemi)
also check your wiring harness from the alternator if there is no bare wires and sometimes wires get cut underneath the intake manifold. just an idea
Old Nov 10, 2006 | 05:29 PM
hondab1015's Avatar
Thanks for the help, I guess let the hunt begin. I do have a helms, and I guess since it happend when I start to move Ill start with the VSS.
Old Apr 6, 2011 | 08:41 PM
poormanstyperb16's Avatar
when you find the problem and solve it =D please reply to me my 99 Si is having the same problem but i havent check my 02 sensor or anything like that.
let me know its my DD car too.
Old Apr 6, 2011 | 08:55 PM
slammed4dreg's Avatar
Default Re: Amp fuse keeps blowing, 00 Si EM1
sounds like this happens to em1's often
monsterCHILD
Jan 6, 2011 04:28 PM
_skitzo_
Jun 3, 2007 08:16 PM
merch1
Mar 6, 2005 11:07 AM
GotGSR
Sep 2, 2004 08:59 AM
PatrickGSR94
Apr 6, 2003 05:46 PM
