Should i upgrade fuel pump and injectors?
Im getting ready to do the following to my B16b head...
BC 4's
Cam gears
BC flat faced valves (with 3 angle)
BC springs
BC Ti retainers
BC thin head gasket
Getting tuned with hondata s200. My question is at what point should i upgrade the fuel pump and injectors? If now is a good time to do this what size injectors?
BC 4's
Cam gears
BC springs
BC Ti retainers
BC thin head gasket
Calculate your horsepower and this will tell you what you need to know.
http://www.rceng.com/technical.htm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rip94delsol »</TD></TR><TR><TD CLASS="quote">i would go with some 310's @ least, also pm'd</TD></TR></TABLE>
yeah 310's should be sufficient, also get a walbro 255 it will help when your on the dyno
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beaneg6 »</TD></TR><TR><TD CLASS="quote">
dont he need more then 255
</TD></TR></TABLE>dont he need more then 255
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Steven. »</TD></TR><TR><TD CLASS="quote">
dont he need more then 255</TD></TR></TABLE>
for a fuel pump? no 255 is fine
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16b-EJ8 »</TD></TR><TR><TD CLASS="quote">Now should i get peak and hold...or saturated? Whats the difference?</TD></TR></TABLE>
peak and hold you need a resistor box, saturated you dont but on saturated your limited to a certain amount of cc's
B16b-EJ8
10
Nov 11, 2006 08:49 AM
b16nonoy
15
Jul 10, 2006 12:29 AM
