ls swap?
You will need the following from the 1994-1995 Integra:
Engine
Tranny
Timing side engine mount and bracket
Front side tranny bracket
Rear tranny/engine bracket
A/C mount bracket if you don't plan on running A/C; 1997 CR-V if you want to keep A/C
Axles
Intermediate shaft (bolts to the back of the block and hooks the left axle to the tranny)
Shift linkage
Exhaust manifold
Catalytic convertor
ECU (any 1992-1995 Integra LS P75 will do)
Upper and lower radiator hoses
You'll keep your stock Civic front anti-roll mounts that bolt to the underside of your frame rails, you'll keep your rear engine mount, and you'll keep your upper tranny mount/bracket too. i suggest buying an Energy Suspension brand three piece mount insert kit to stiffen up those front mounts and the rear mount - order them for your Civic, not an Integra
You'll also need a Del Sol VTEC or Integra LS, or Type R throttle cable too.
EDIT
I originally posted this for a guy with a Dx, which has a 4-wire o2 sensor, so for your CX you'll want to get the engine harness for the Integra too, or just wire up the 4 o2 sensor wires, because your Cx only has a 1-wire o2 sensor in it and on its engine harness.
Modified by B18C5-EH2 at 4:57 PM 11/9/2006
Engine
Tranny
Axles
Shift linkage
Exhaust manifold
Catalytic convertor
EDIT
D16SiHatch
13
Mar 29, 2008 05:05 PM
2000CivicEK
May 15, 2007 01:44 AM
SpoonFedHatch
Feb 20, 2003 12:03 PM
