Tranny help!!!
Old Nov 9, 2006 | 11:02 AM
EGwhat!!!'s Avatar
Default Tranny help!!!
well i was driving around today taking care of some bills and when i pulled into my driveway and put the car in nuetral. i hear this loud noise coming from the tranny almost like something is spinning and hitting. any ideas of to what it could be?? i was thinking throw out bearing but im not sure any suggestions and insight would be greatly appreciated. mind you i dont run my car hard at all and always stay within the speed limit. ive had enough speeding tickets already. oh and my setup is a 92 vx with a 99 b18c1.
:EDIT: when i put it in gear the noise goes away
Old Nov 9, 2006 | 11:05 AM
instructor74's Avatar
Default Re: Tranny help!!! (EGwhat!!!)
If the clutch is out and you still have the noise in neutral then my first guess is going to be the input shaft bearing. Try pushing the clutch in to see if the noise goes away. If it does then it is a slam dunk problem is in the trans
Old Nov 9, 2006 | 11:06 AM
EGwhat!!!'s Avatar
Default Re: Tranny help!!! (instructor74)
noise went away. is that something that could be fixed easily?? would it be safe to drive the car like this?
Old Nov 9, 2006 | 11:20 AM
Change the fluid out in the trans put in a good mtf and see what happens. In order to change the isb you have to take the trans out and take it comp apart. It should run for awhile better start saving $$ for a rebuild or replacement
Old Nov 9, 2006 | 11:22 AM
EGwhat!!!'s Avatar
god damnit. anyone wanna buy a b18c1. time to go k-series. oh well thanks for your help
Old Nov 9, 2006 | 11:28 AM
Bense's Avatar
from PM convo, figured I'd paste this into hear for search purposes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense &raquo;</TD></TR><TR><TD CLASS="quote">when vehicle is stopped, and clutch pedal is on the floor. transmission is doing nothing.
when you are parked, engine is running, shifter is in neutral, and the clutch pedal is not pressed. the mainshaft on the transmission is spinning, throwout bearing is doing nothing. If you hear the noise then, then it's something in the trans or the engine.
whenever you do press the clutch, it takes a few seconds for the trans to stop spinning. trans in neutral, engine running, clutch to the floor, if you continue to hear the noise, it's the throwout bearing or pilot bearing.</TD></TR></TABLE>
Old Nov 9, 2006 | 11:29 AM
Bense's Avatar
http://www.d-series.org/forums...54828
PS: both of your avatars look very similiar at first glance.
Old Nov 9, 2006 | 11:30 AM
.Radical_Edward.'s Avatar
Bounty - € 8,000,000
Input Shaft Bearing Definitely. I just had the same problem and the whole trann yalmost **** on me. The part is about $26-$35 bucks from Honda depending on where you live. Or you could just swap out the tranny. You can get another Hydro tranny for cheap.
There is a write up in the FAQ on how to change out the ISB. Definitely get a Helms. :thumb
Old Nov 9, 2006 | 11:35 AM
EGwhat!!!'s Avatar
Default Re: Tranny help!!! (.Radical_Edward.)
is this something that could be done in like a day
Old Nov 9, 2006 | 11:42 AM
took me about 4 hours from start to finish. You could get it done in a day if you had a garage and lighting and started around 9 am
Old Nov 9, 2006 | 11:46 AM
mafia's Avatar
I Had a 100% problem on a 96 prelude. When you are parcked open your hood and try to hold the clutch pusher thinggy (its on front of tranny, in the middel of radiater but on tranny.)...Not sure what its called sorry. Im more then sure thats the problem. Hope it helps have fun!
TRY THIS BEFORE YOU SWAP YOUR TRANNY~~~!!~~!!~!!
Old Nov 9, 2006 | 12:07 PM
EGwhat!!!'s Avatar
Default Re: Tranny help!!! (mafia)
just got back and i am stumped the noise went away completely i even drove on the freeway and nothing
Old Nov 9, 2006 | 12:11 PM
mafia's Avatar
So what was the problem?
Old Nov 9, 2006 | 12:20 PM
EGwhat!!!'s Avatar
i dont know it just went away. i pulled out of my driveway and you could hear it put as soon as i got about 2 blocks away it was gone completely
Old Nov 9, 2006 | 12:32 PM
mafia's Avatar
i think it is what i was talking about. (you know were you bleed you clutch) that thinggy can get loose sometimes.
Old Nov 9, 2006 | 12:33 PM
EGwhat!!!'s Avatar
it probably was but the good thing is that its gone. but could this be a sign of tranny failure to come??
baboonstyle
Oct 9, 2006 11:04 AM
Ge-money
Sep 12, 2006 06:23 AM
CPR
Dec 14, 2005 10:26 PM
civicmark
May 25, 2004 09:16 PM
PureBlood
Sep 30, 2002 11:40 AM
