will a gsr motor fit in a ls integra
Old Nov 9, 2006 | 10:47 AM
Untouchable13's Avatar
Default will a gsr motor fit in a ls integra
hey i was wondering if u can just pull a ls motor out of a ls n put a gsr motor in. just a general question.
dohcMONSTER's Avatar
Default Re: will a gsr motor fit in a ls integra (Untouchable13)
yes you just need to wire up a few sensors, knock and vtec. axles and mounts and everything else is the same
Old Nov 9, 2006 | 11:21 AM
BlueIntegraBoy's Avatar
Default Re: will a gsr motor fit in a ls integra (dohcMONSTER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcMONSTER &raquo;</TD></TR><TR><TD CLASS="quote">yes you just need to wire up a few sensors, knock and vtec. axles and mounts and everything else is the same </TD></TR></TABLE>
He won't need axles or mounts if he reuses his.
Old Nov 9, 2006 | 11:26 AM
Default Re: will a gsr motor fit in a ls integra (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">
He won't need axles or mounts if he reuses his.</TD></TR></TABLE>
thats what i meant
Old Nov 9, 2006 | 11:29 AM
SYTFU Tommy.'s Avatar
extend some wires....run vtec and knock senor wires into the ecu
GoldCoin's Avatar
dont rip the boots when your taking them out.
i done that to many times.
Old Nov 9, 2006 | 03:13 PM
what do u mean by knock
Old Nov 9, 2006 | 03:22 PM
GoldCoin's Avatar
knock sensor
Old Nov 9, 2006 | 03:39 PM
PLAGUED_DB7's Avatar
Default Re: will a gsr motor fit in a ls integra (DC TWOin IT)
AS stated before you will need to wire up Vtec, and knock sensor. Everything else is swapable.
Old Nov 9, 2006 | 04:12 PM
ac_attak's Avatar
Also use a gsr, b16, or type r tranny. The ls tranny works but the gearing sucks.
Old Nov 9, 2006 | 04:21 PM
JDMbiAtcH's Avatar
Default Re: will a gsr motor fit in a ls integra (ac_attak)
Old Nov 9, 2006 | 05:59 PM
98GSRDC2's Avatar
Yes.
Old Nov 12, 2006 | 08:44 PM
honinspire02's Avatar
oh yeah tjey the same size in general.. it will drop right in
Old Nov 12, 2006 | 10:02 PM
cooltron's Avatar
Default Re: will a gsr motor fit in a ls integra (gsr1416)
yea what that guy said about the tranny change, switching gears is just horrible.
Old Nov 12, 2006 | 11:41 PM
davidluko's Avatar
Default Re: will a gsr motor fit in a ls integra (cooltron)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cooltron &raquo;</TD></TR><TR><TD CLASS="quote">yea what that guy said about the tranny change, switching gears is just horrible.</TD></TR></TABLE>
If by 'switching gears' you mean shifting, shifting feels the same between LS, GSR, Si, or ITR trannies... it's the shorter gearing that helps.
Old Nov 13, 2006 | 12:46 PM
92whtgsr's Avatar
wont fit
B16A3Civic*Eg
Aug 15, 2006 03:21 PM
B16A3Civic*Eg
May 22, 2006 10:23 PM
hondaboyz94si
26
Dec 18, 2005 11:01 AM
Austinbionic316
Feb 5, 2004 08:47 AM
All_Motor_Rex
Feb 3, 2004 02:17 PM
