help with brakes....
Old May 7, 2002 | 12:52 PM
Altered_Ego's Avatar
Default help with brakes....
I was about to purchase the AEM big brake kit...can i still run my 16 inch wheels or should I go with the 17's??
Old May 7, 2002 | 12:58 PM
owen_the_soyboy's Avatar
Default Re: help with brakes.... (Altered_Ego)
dont do it unless you are getting the kit with the monster yummy aluminum calipers.
the cheap but effective way to better brake feel/fade resistance is GSR front knuckles and ITR calipers over ITR factory/brembo rotors. no joke.
plus you can run smaller lighter wheels (15") with sticky yet less expensive tires with much better and much more tire selection in the 15" size.
Old May 7, 2002 | 01:01 PM
Default Re: help with brakes.... (owen_the_soyboy)
here is a pic of the brakes i was looking at....
here is the info about them:
Four Piston Caliper Big Rotor Brake Kit
For customers with high horsepower applications or who want the ultimate in clamping power, AEM offers Four Piston Brake Calipers in conjunction with its Big Rotor Replacement Kit. These calipers are the same design as ones used on Porsches and feature a larger pad area that provides greater stopping power. Additionally, the caliper’s four-piston design allows for repeated pedal application with minimal fade or decrease in braking efficiency. Each application is designed so that the AEM caliper’s piston area is similar to the stock caliper’s piston area to maintain O.E. pedal travel. This system includes all of the features found in AEM’s O.E Caliper Big Rotor Brake Kit.
Old May 7, 2002 | 01:10 PM
Doctor CorteZ's Avatar
yuck , and your not fitting 16's , some balla type dude has em aroud town and his 17's wouldnt fit
and the 150 dollar AEM pads are total garbage
Old May 7, 2002 | 01:12 PM
vtecvoodoo's Avatar
Future Texas Boy
Community Builder
Default Re: help with brakes.... (Doctor CorteZ)
fastbrakes.com
Upgrading you brakes and jumping up to a 17" wheel kinda defeats the purpose.
Ryan
Old May 7, 2002 | 01:15 PM
mantic6t9's Avatar
Default Re: help with brakes.... (vtecvoodoo)
fastbrakes.com
Ryan
Agreed
Old May 7, 2002 | 01:41 PM
Default Re: help with brakes.... (mantic6t9)
so you all would just use the integra setup and stay with the 16's??
Let me know the setup that you would use...that would be very helpful...thanks!
Old May 7, 2002 | 01:48 PM
TodaSi's Avatar
I ran the Fastbrakes ITR spec brakes and re-drilled rotors on my 99 Si. Worked great on the track and auto-x. Plus I used the stock 15" rims and had my picK of ITR brake pads.
Now in my CX I'm running the Wilwood dynalite kit (2.5 lbs vs about 10 lbs stock)with 2 piece 11" rotor from Fastbrakes. It fits under my Volk CE28n 15x7 rims and my Rota Circuit 8 15x6.5 rims. No spacer, no grinding/sanding. It's the Superlite II (4.5 lbs) caliper that people are having problems with.
[Modified by TodaSi, 5:49 PM 5/7/2002]
Old May 7, 2002 | 01:49 PM
vtecvoodoo's Avatar
Future Texas Boy
Community Builder
get the fastbrakes wilwood kit
http://www.fastbrakes.com
Ryan
Old May 7, 2002 | 01:54 PM
man....those things are a lot less than the other kits out there! Thanks guys for all the info! I noticed they make a rear kit too...i will have to convert my car from drums to disk in the back....how hard is that?? its going on a 97 hatch....
Old May 7, 2002 | 01:57 PM
Dodger2940's Avatar
Default Re: help with brakes.... (TodaSi)
How much this kit run you I am thinking of getting some for my Si
Old May 7, 2002 | 01:58 PM
vtecvoodoo's Avatar
Future Texas Boy
Community Builder
It`s easy. the kit comes w/ everything you need.
Ryan
blundar
Suspension & Brakes
Aug 18, 2005 08:17 AM
ef-sihatch
Nov 21, 2004 06:56 AM
BSpec24
Jan 2, 2002 07:03 PM
Short_Shifter
Dec 27, 2001 12:57 PM
sicilian2k1
Nov 15, 2001 03:18 PM
