92-95 fog light question
well i got the crappy ebay wiring hardness and still cant figure out why they wont turn on... so i was wondering will it hurt if i tap it to my parking lights and have them on when the parking lights are on ?
i think u will probably be blowing the fuse if u do that
u can always just wire up your own harness
it isnt realy that hard
down load the diagram from pasword jdm and u should be able to hook it up for like 5 or 10 bucks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch96y7 »</TD></TR><TR><TD CLASS="quote"> http://www.handa-accessories.c...s.pdf
the wiring should be the same </TD></TR></TABLE>
No, it's not. The DEPO wiring is nothing like the OEM wiring.
there is only two ground for the foglights
its from the first harness theres a ground then uner the dash there is a wire for the groung you have to ground the wire with the realay in the same spot
do u have your connectors plugged in right under your dash ontop pf your fuse box
and does your switch light turn on
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkipMic2006 »</TD></TR><TR><TD CLASS="quote"> so i was wondering will it hurt if i tap it to my parking lights and have them on when the parking lights are on ?</TD></TR></TABLE> fogs have to turn off when highbeams turn on.. according to state inspection, the parking lights are always on when the switch is on for just parking light, parking lights and head lights<high and low beams> .
i havent try that yet but here what i did tho... i put 2 grounds to theneg side of the battery and the postive side for the power and nothing happen. but what side do i use for the fuse box tho ?
this pic isfrom somebody esle but same wireing and plugs
i know that white plug goes to the switch and one of them is the ground and other 2 not sure it goes tho
check your fuse in side the little box make sure it has the right rating i dont know what your doing to ur battery but i think your trying to test em right
do u think u can post a pic of your wiring harness that you have and it will probably be alot easyier to explain
the white plug goes to the swtch i know that for sure and other 3 i'm not sure asdn the rest of the hardness is just fog light plug, inline fuse and a realy then to the battery.
judging from that picture, it looks like u got the same exact kit i got on ebay. Ok, the white plug plugs into your switch, obvious. You should have two different harnesses, one that goes under ur hood and the other that goes inside the car. The red wire connects both harnesses together, it's easy to tell, the plug matches. The yellow wire goes into your fusebox and the other wire is your ground for the inside of the car.
As for your foglights not turning on, i can pretty much bet it's your switch, you have a bad switch.
When I bought mine on ebay, i had the same problem and came to find out that my switch was bad so i bought an oem one, now it works fine.
that white plug goes to the switch, the yellow female connector goes to accessory fusebox spots C, D, or E show in this picture
the black wire with the ring terminal is grounded, and the red wire connects to the red wire coming from the engine bay fog harness
but from what you said, the crappy depo switch sucks so it's probably bad and that's your problem
9.3.S.I.L.U.D.E.
Dec 28, 2008 12:28 PM
shadohconspiracy
Feb 21, 2008 07:18 PM
