92-95 fog light question
Old 11-08-2006, 07:03 PM
4DRmafia's Avatar
Default 92-95 fog light question
well i got the crappy ebay wiring hardness and still cant figure out why they wont turn on... so i was wondering will it hurt if i tap it to my parking lights and have them on when the parking lights are on ?
Old 11-08-2006, 07:15 PM
4DRmafia's Avatar
no answer? shhhhiiyt
Old 11-08-2006, 07:17 PM
hatch96y7's Avatar
Default Re: (SkipMic2006)
i think u will probably be blowing the fuse if u do that
u can always just wire up your own harness
it isnt realy that hard
down load the diagram from pasword jdm and u should be able to hook it up for like 5 or 10 bucks
Old 11-08-2006, 07:33 PM
4DRmafia's Avatar
i dont see anywhere to download the diagram off from passwordkjdm tho.. i cant find it !
Old 11-08-2006, 07:37 PM
hatch96y7's Avatar
hold on
Old 11-08-2006, 07:38 PM
4DRmafia's Avatar
okay and thanks man
Old 11-08-2006, 07:42 PM
hatch96y7's Avatar
http://www.handa-accessories.c...s.pdf
the wiring should be the same
Old 11-08-2006, 07:49 PM
HT White Ops
Eran's Avatar
Default Re: (hatch96y7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch96y7 &raquo;</TD></TR><TR><TD CLASS="quote"> http://www.handa-accessories.c...s.pdf
the wiring should be the same </TD></TR></TABLE>
No, it's not. The DEPO wiring is nothing like the OEM wiring.
Old 11-08-2006, 07:50 PM
92'si's Avatar
Default Re:
might be a gay question but are they grounded properly? and does your switch have power?
Old 11-08-2006, 07:51 PM
hatch96y7's Avatar
Default Re: Re: (92'si)
thats not what im saying i am saying he can rewire everything himself
Old 11-08-2006, 07:56 PM
4DRmafia's Avatar
i tired all the grounds from the battery to be sure it working and did the same thing to the postive side for power on the battery and nothing works
Old 11-08-2006, 08:14 PM
hatch96y7's Avatar
there is only two ground for the foglights
its from the first harness theres a ground then uner the dash there is a wire for the groung you have to ground the wire with the realay in the same spot
do u have your connectors plugged in right under your dash ontop pf your fuse box
and does your switch light turn on
Old 11-08-2006, 08:32 PM
crimsonv4mpire's Avatar
Default Re: 92-95 fog light question (SkipMic2006)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkipMic2006 &raquo;</TD></TR><TR><TD CLASS="quote"> so i was wondering will it hurt if i tap it to my parking lights and have them on when the parking lights are on ?</TD></TR></TABLE> fogs have to turn off when highbeams turn on.. according to state inspection, the parking lights are always on when the switch is on for just parking light, parking lights and head lights&lt;high and low beams&gt; .
Old 11-08-2006, 08:34 PM
4DRmafia's Avatar
i havent try that yet but here what i did tho... i put 2 grounds to theneg side of the battery and the postive side for the power and nothing happen. but what side do i use for the fuse box tho ?
Old 11-08-2006, 08:37 PM
4DRmafia's Avatar
this pic isfrom somebody esle but same wireing and plugs
i know that white plug goes to the switch and one of them is the ground and other 2 not sure it goes tho
hatch96y7's Avatar
check your fuse in side the little box make sure it has the right rating i dont know what your doing to ur battery but i think your trying to test em right
do u think u can post a pic of your wiring harness that you have and it will probably be alot easyier to explain
Old 11-08-2006, 08:38 PM
hatch96y7's Avatar
okay the white connector goesi into the switch or the harness
and what other plugs do u got
Old 11-08-2006, 08:39 PM
4DRmafia's Avatar
i think the yellow wire with the femalespade goes to the fuse box some where and the red wire ?
Old 11-08-2006, 08:40 PM
4DRmafia's Avatar
the white plug goes to the swtch i know that for sure and other 3 i'm not sure asdn the rest of the hardness is just fog light plug, inline fuse and a realy then to the battery.
Old 11-08-2006, 08:54 PM
hatch96y7's Avatar
there shouldnt be any wire directly to the battery
Old 11-08-2006, 09:08 PM
4DRmafia's Avatar
the only wire directly to the battery is the power wire with a ring termal on it
Old 11-08-2006, 09:14 PM
4DRmafia's Avatar
or if i have to wire it myself from this one...
Old 11-08-2006, 10:06 PM
byronl's Avatar
judging from that picture, it looks like u got the same exact kit i got on ebay. Ok, the white plug plugs into your switch, obvious. You should have two different harnesses, one that goes under ur hood and the other that goes inside the car. The red wire connects both harnesses together, it's easy to tell, the plug matches. The yellow wire goes into your fusebox and the other wire is your ground for the inside of the car.
As for your foglights not turning on, i can pretty much bet it's your switch, you have a bad switch.
When I bought mine on ebay, i had the same problem and came to find out that my switch was bad so i bought an oem one, now it works fine.
Old 11-10-2006, 03:32 PM
zxstrikerxz's Avatar
yellow to fuse #2 socket, red is to the harness's power, and ground etc. and white to switch
Old 11-10-2006, 04:00 PM
2coupes's Avatar
that white plug goes to the switch, the yellow female connector goes to accessory fusebox spots C, D, or E show in this picture
the black wire with the ring terminal is grounded, and the red wire connects to the red wire coming from the engine bay fog harness
but from what you said, the crappy depo switch sucks so it's probably bad and that's your problem
Luke G.
Lighting
04-04-2009 10:12 AM
9.3.S.I.L.U.D.E.
12-28-2008 12:28 PM
shadohconspiracy
02-21-2008 07:18 PM
Vtak DOHCTA
12-28-2005 02:03 PM
EK Josh
07-26-2005 09:38 AM
Quick Reply: 92-95 fog light question
