thermostat opens idle. not under load.
Old Nov 8, 2006 | 06:00 PM
shortyz21's Avatar
Default thermostat opens idle. not under load.
Why the expletive is this hapening, if i let my car idle in my shop the thermostat opens fine.
but if i drive it and put it under load the thermostat will not open.
tested thermostat.
new head.
new headgasket.
bled system 8000 times.
i really need help here guys cause this is driving me ******* insane, ive been trying to solve this problem for 3 weeks with no luck.
should i just drill a hole in the side of my thermostat and say fu.ckit?
Modified by shortyz21 at 7:11 PM 11/8/2006
Old Nov 9, 2006 | 07:58 AM
shortyz21's Avatar
Default Re: thermostat opens idle. not under load. (shortyz21)
anyone.
Old Nov 9, 2006 | 08:22 AM
locash's Avatar
How do you know that the thermostat is not opening "under load"? Do you have a little camera in there?
Old Nov 9, 2006 | 04:59 PM
shortyz21's Avatar
Default Re: thermostat opens idle. not under load. (locash)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by locash &raquo;</TD></TR><TR><TD CLASS="quote">How do you know that the thermostat is not opening "under load"? Do you have a little camera in there?</TD></TR></TABLE>
simple. my gauge goes way up. i get out of my car and grab my bottom hose and its cold.
can i get another witty response? cause im not in the mood
Old Nov 9, 2006 | 06:43 PM
chasemyhonda's Avatar
B A N N E D
Ive had Issues with the Cheap thermostats from Autozone, Advanced, Pep boys.. all those part stores ive had issues with it. i got a OEM honda one and it worked like a charm. Friend has a Mugen one and it is just as good. just more expensive
Old Nov 9, 2006 | 07:06 PM
shortyz21's Avatar
Default Re: (blindingxenon)
i tested it out of the car also, worked great..
i dont think its an issue with the thermostat.
Old Nov 9, 2006 | 07:36 PM
B A N N E D
Last time you had a coolant flush? how do the bearings sound in the waterpump? cooling system is very short so it shouldnt hard to diagnose.
Old Nov 9, 2006 | 07:52 PM
jdmsiR20's Avatar
just a thought...
i had my thermostat installed backwords, and the seal wasn't on fully... gave me a funky temp reading until i fixed it
Old Nov 9, 2006 | 08:18 PM
B A N N E D
lol ive tried to install one backwards and it wouldnt go at all. so i dont know how you installed yours backwards
Old Nov 10, 2006 | 02:09 PM
shortyz21's Avatar
its installed correctly.
with the pin up also.
nothing is blocked, cause when i idle it to warm it opens and the car is able to drive.
Old Nov 10, 2006 | 07:06 PM
PyroProblem's Avatar
Default Re: (shortyz21)
This sounds like your waterpump blades are shot...No circulation will cause that lower hose to be cold just like your describing...
How old is the waterpump?
Old Nov 11, 2006 | 08:15 AM
shortyz21's Avatar
Default Re: (PyroProblem)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PyroProblem &raquo;</TD></TR><TR><TD CLASS="quote">This sounds like your waterpump blades are shot...No circulation will cause that lower hose to be cold just like your describing...
it seems to be circulating fine, my heater works great and if i pull a hose at idle its pumping good.
also i sed that if i let it idle, thermo opens and then i can drive it anywhere i want. but if i take it on the road cold. it will not open.
i am gonna put in another thermostat today and see what happens.
Old Nov 12, 2006 | 08:11 AM
shortyz21's Avatar
imma pull the water pump out as a last resort.
the OEM thermostat worked a bit better but it did the same thing irractically.
Old Nov 14, 2006 | 08:16 PM
Check the waterpump man. Im 99.9% sure its your problem.
Old Nov 17, 2006 | 01:27 PM
shortyz21's Avatar
i ended up running straight water in my system for 6 months, heres what hapened:
the fins on the water pump got little dimples of rust on them, and i believe this was causing cavitation of the water pump at higher RPM/temperature.
i replaced it all and finally i replaced my water pump and it solved the problem.
moral of the story, always run a little bit of antifreeze in the rad to keep that **** from rusting.
THE END!
gian_ed7b16a1
21
Feb 12, 2016 08:40 PM
schumi
Jul 17, 2008 03:25 PM
TrueUntilDeath.com
Feb 7, 2008 08:20 PM
Schultzie
Aug 11, 2007 02:32 PM
homeskillet
Dec 24, 2004 09:22 PM
