Water Leak Problem.
1996 Hatchback.
Okay so i know its not coolant nor gas thats making my driver side carpet wet.. i know its water.. cus when it started raining thats when i started building up a puddle on my carpet. (i searched by the way. i must suck at it cus i only got few results and all it was were coolant or gas leak but nothing about water) what could it be? where could water be possibly leaking?
you said it rained well there are lot places where water can enter.you gonna have to search underneath the carpet firewall and everything. there some rubber seals that go bad underneath the carpet
I have the same problems, but mine is because theres a giant rip in the sheet metal that makes up my floorboard. If you lift up the carpet, you can see concrete.
Jack up your car and make sure theres not a hole in the floor. im serious.
i fixed the tire well problem it was entering through the tap screws for the vents.. i sealed them with clear silicone. its just the driver side that im having hard time finding whats causing the water to seep in.
have u had anywork done to you're car recently , i had the the same problem on my honda civic vti ek4 , best thing to do is a hose the car down , spray front end of the car while some one is in the car with a bright torch , thats what exactly what i did to find the problem ..!!!
Water usually is condensed under the carpet, and stays there. Could just be that it got wet once from a spill. If not, you got a leak through the window, door, air blower, or frame of car.
PatrickGSR94
Jan 30, 2005 02:38 PM
Kelvin96GSR
Nov 29, 2001 10:48 AM
