HELP!!!! OEM raybrig FOG light problem!!!
Old Nov 8, 2006 | 05:23 PM
TheTurtle's Avatar
Default HELP!!!! OEM raybrig FOG light problem!!!
I have searched and searched some more with no help!
heres the deal I have the oem fog lights on my 00 civic, the fuse keeps on blowing!!! I can put a 30 amp fuse in there and it continues to blow.
I really dont know what to do! can anyone please help?
Old Nov 8, 2006 | 05:37 PM
hatch96y7's Avatar
Default Re: HELP!!!! OEM raybrig FOG light problem!!! (TheTurtle)
if u keep putting the wrong amp fuse it will blow so go to the regular size fuse then check and see if anything is grounding out
see if any wires are lose and touching eachother
then if it keeps blowing try checking the terminals u plugged ur connectors into
Old Nov 8, 2006 | 05:41 PM
f20bej1's Avatar
Default Re: HELP!!!! OEM raybrig FOG light problem!!! (hatch96y7)
water might got inside the light assembly or grounding
Old Nov 8, 2006 | 05:51 PM
TheTurtle's Avatar
could it be the relay that is connected to the ground terminal?
Old Nov 8, 2006 | 05:53 PM
f20bej1's Avatar
Default Re: (TheTurtle)
very possible
Old Nov 8, 2006 | 05:55 PM
TheTurtle's Avatar
anymore input? I guess i will go to honda tomorrow and see if I can find one of those relays
Old Nov 8, 2006 | 09:21 PM
Slammed Civic Si's Avatar
i had this happen to me and it was the bulbs they were drawing too much current. DO NOT KEEP ANYTHING MORE THAN A 10 AMP FUSE IN THERE. it will cause other fuses to blow or possibly melt some wiring. on mine it blew a fuse that made my guages not work unles my parking lights were on and along wiht mass other stuff. try a lower wattage bulb and see if that changes it
Old Nov 8, 2006 | 10:15 PM
aznvietboi87's Avatar
its probably bad wiring or a bad ground.
Old Nov 8, 2006 | 11:19 PM
marshun's Avatar
Default Re: (aznvietboi87)
must be grounding out somewhere or the system is just gettin overloaded.
Old Nov 9, 2006 | 09:12 PM
TheTurtle's Avatar
fixed! thanks so much guys!
solution: tightened ground wire/relay to location! (and it is a 15 amp fuse btw... it is what came in there factory, refer to the directions on handaaccessories.com! )
Old Nov 10, 2006 | 02:27 AM
marshun's Avatar
sweet!
6footmidget
Aug 27, 2008 11:29 PM
Kr4nG
May 18, 2008 05:10 AM
SYTFU Tommy.
Aug 10, 2007 11:29 PM
Mag00n
Nov 9, 2003 11:39 AM
