Cluster wiring problem
Old Nov 8, 2006 | 03:48 PM
pdiggitydogg's Avatar
Default Cluster wiring problem
trying to put (what I am told) a 88 cluster in my 90 civic hatch.
Im having a problem with the wiring pinouts...
Here is my B plug:
Green/Blue
Yellow
Yellow/White
Yellow/Red
Green/Orange
Red/Black
Red
Black/Yellow
White/Blue
Blue
Yellow/Green
And this is what its "supposed to be":
Should I repin the connector? Is the information above wrong? If it is wrong, does anyone have the right information (as well as for connector A)??
Why do I only have 11 wires?
Old Nov 8, 2006 | 07:49 PM
crxnj's Avatar
Default Re: Cluster wiring problem (pdiggitydogg)
i have a 89 crx plug in my face and it doesnt look like yours,,it looks like the later picture..
whats strange is i have both 91 and 89 plugs right here but neither look like your plug. maybe you have one of the different model clusters? on your 88 cluster read the code, mine says "NS" and the one that most dont have is "ND".
Old Nov 9, 2006 | 04:40 AM
i'll have to check that later...where does it say that?
I repinned both of my connectors to match the bottom connector, and I have a slew of problems
Parking brake light becomes hatch light
brake and door lights on all the time...except when the headlights are turned on
Fuel level doesnt work
Tach doesnt work
Probably more, but I only turned it on, saw those, said the hell with it, went to bed
Old Nov 9, 2006 | 08:20 AM
crxnj's Avatar
Default Re: (pdiggitydogg)
on my cluster its on the back in the center and on the bottom,,the top one says nst and bottom says ns3 so mine is ns cluster..
but go to ef-honda.com in the knowledge base,and click on 00 si cluster install,,it has the colors of the wires and where there supposed to be for 90-91 cluster plug
Old Nov 9, 2006 | 11:03 AM
its NS
I just got back from playing with the thing for over 2hrs, and got a few of the pins figured out and switched over. I still have no lights for it, but at least I have temp, fuel (i think...) and tach
Old Nov 9, 2006 | 11:55 AM
Oh, this is what I figured out:
1 - L signal
2 -
3 - Temp
4 -
5 -
6 - Door
7 - Brake
8 - Oil
9 - CEL
10 -
11 -
12 - Tach
1 - Ground
2 -
3 -
4 - Hatch
5 - Seat Belt
6 - Fuel
7 -
8 - R Signal
If anyone can look these up in a manual, we can figure out what plugs they are, exactly? Then, perhaps I can figure out what the rest are.....like the instrument lights...
I know the wire for that is red, and I ran it across the entire board with the lights on...but didnt notice anything other than blowing the fuse once...
Found this thread:
https://honda-tech.com/zerothread?id=1732102
Seems to match what I have going on...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecn8ive &raquo;</TD></TR><TR><TD CLASS="quote">
90-91 CRX gauge cluster pinouts -------------------------------
C.
1. Left Turn ---- (Green/Blue)
2. High Beam ---- (Red/Blue)
3. Coolant Temp -- (yellow/Green)
4. Dash Brightness ----- (Red)
5. Gauge Lights ----- (Red/Black)
6.
7. E-Brake ---- (Green/Red)
8. Oil Pressure --- (yellow/red)
9. Check Engine Light ---- (Green/Orange)
10. 12v Power ---- (Black/Yellow)
11. Battery/Alternator Light ---- (White/Blue)
12. Tachometer --- (Blue)
D.
1. Ground ---- (Black)
2.
3.
4. Trunk ---- (Green/Black)
5. Seat Belt ---- (Blue/Red or Blue/yellow)
6. Fuel Gauge --- (Yellow/White)
7. 12v Power ---- (Yellow)
8. Right Turn --- (Green/Yellow)
Problem solved?
90+ views and i get help from 1 person
Modified by pdiggitydogg at 4:59 PM 11/9/2006
Old Nov 9, 2006 | 01:48 PM
vtecn8ive's Avatar
i'll have a write up for you tomrorow. i gotta look through the manual.
Old Nov 9, 2006 | 03:40 PM
mrtoastyjr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">i'll have to check that later...where does it say that?
Tach doesnt work
Probably more, but I only turned it on, saw those, said the hell with it, went to bed</TD></TR></TABLE>
rotfl sorry to hear that you having problems but that statement made my day cause i do the same thing
Old Nov 9, 2006 | 07:12 PM
you know, its interesting driving at night with no cluster lights
even worse when there is a cop right behind...used my cell phone to light the speedo ....god damn i need to figure this out
Old Nov 9, 2006 | 07:25 PM
vtecn8ive's Avatar
Its even better driving a car that has just a seat (no carpet or passenger seat or hvac system OR DASH) hehe and driving that around for a couple of days waiting for your daily drive to be fixed
Modified by vtecn8ive at 11:06 PM 11/9/2006
Old Nov 9, 2006 | 08:04 PM
goforbroke's Avatar
MEAT PATTY
Default Re: (vtecn8ive)
88-89 cluster plugs
90-91 cluster plugs
Old Nov 10, 2006 | 05:58 AM
sorry, i know the second pic doesnt work...but those are not right for 88-89 clusters, according to what I have found out.
The 88 cluster I am using matches 90-91 pinouts...or closer anyways. Whats bad is every single site/how-to uses that above information...its why I am having the trouble in the first place
Old Nov 10, 2006 | 06:47 AM
goforbroke's Avatar
MEAT PATTY
Its strange you said the above information isn't correct because its what I used to put a 2000 civic si cluster in my 88std.
Old Nov 10, 2006 | 07:35 AM
thats grreat, but none of it matches what i have found
my 88 plugs are closer to 90
Old Nov 10, 2006 | 09:04 AM
goforbroke's Avatar
MEAT PATTY
Do you have a std or a dx?
Old Nov 10, 2006 | 10:34 AM
std
i got it
wiring matches the 90-91 exactly
even found the '88 stamp on the cluster
Old Nov 10, 2006 | 12:58 PM
vtecn8ive's Avatar
I got made up a wiring how-to today. did you still need me to post it?
Old Nov 10, 2006 | 05:56 PM
nah i got it
thanks
itr1235
Mar 16, 2006 01:52 PM
jbs
Dec 5, 2003 09:12 AM
BAZ
Jul 27, 2003 01:34 PM
Turbo Powa
22
Jun 29, 2003 11:45 AM
