Battery Relocation
Old Nov 8, 2006 | 03:30 PM
lude98SH's Avatar
Default Battery Relocation
Im alittle confused on the wiring for this. Do you just ground it to the rear strut tower and run a power line to the starter ? How would it work with the alternator ?
Also what are any safety concerns for doing this ?
And for drag racing would this hurt performance by taking the weight outta the front end and moving it to the rear ?
Old Nov 8, 2006 | 03:34 PM
2lude4u's Avatar
Default Re: Battery Relocation (lude98SH)
Ground it to the chassis somewhere in the rear. The wire that goes up front needs to be split- one wire to the starter, the other to the engine compartment fuse box.
The alternator is hooked up to the engine harness, no modifications needed.
The decrease in weight up front could effect your launching traction some, whether it will be significant is doubtful.
Old Nov 8, 2006 | 03:37 PM
lude98SH's Avatar
Default Re: Battery Relocation (2lude4u)
What size wire is stock because its going to be hard to run that wire into the fuse box if it like 1 guage wire.
Old Nov 8, 2006 | 05:13 PM
2lude4u's Avatar
You use a distribution block so you can send a smaller wire to the fuse box, & a large wire to the starter.
Old Nov 8, 2006 | 06:49 PM
98vtec's Avatar
moderator emeritus
Old Nov 8, 2006 | 07:07 PM
2lude4u's Avatar
Default Re: Battery Relocation (98vtec)
Haha, I guess that's one way of doing it.
Old Nov 8, 2006 | 08:33 PM
lude98SH's Avatar
What gauge wire is that ? How did you run it to the fuse box ?
Old Nov 8, 2006 | 10:19 PM
barroomhero's Avatar
another thing to keep in mind in reguards to your original post (you mentioned drag racing)
With the battery relocated in the trunk most (if not all) tracks will require you to have an externaly mounted kill switch on the back of the car.
Now with that in mind, you only need one taillight at the track. so what you can do is mount a switch underneath one of your taillights so with the light in place it doesnt show... then take the taillight off at the track.
Old Nov 9, 2006 | 12:16 AM
pinecone's Avatar
Default Re: (barroomhero)
i don't think relocating the battery will really move that much weight to the rear.
Also what drap strip is going to check and see if the battery is in the front or rear of the car. Battery kill switches are on high powered cars for safety reasons, don't see much reason for one on a lower powered car.
Old Nov 9, 2006 | 05:26 AM
ewok_poacher's Avatar
I am about to put my battery in the trunk of my 98 prelude cuz I ran out of room under the hood.
Old Nov 9, 2006 | 09:29 AM
lude98SH's Avatar
Default Re: Battery Relocation (ewok_poacher)
Would something like this be allowed ?
http://store.summitracing.com/...w=sku
Along with the battery switch.
Old Nov 9, 2006 | 09:40 AM
2lude4u's Avatar
Yeah, most tracks want it to be securely attached & have a kill switch when there is not a "firewall" between you & the battery. An item like that is specifically made to secure the battery so it should be ok as long as there is something that is securely holding the battery down (hard to tell from the pic).
tangerinebeast
Jan 5, 2011 03:48 PM
russianswty
Dec 22, 2006 06:57 PM
philkehn
21
Jul 5, 2006 08:29 PM
User 42624
Jul 19, 2005 11:41 PM
