B20 Blocks
Old Nov 8, 2006 | 11:56 AM
beast59's Avatar
Default B20 Blocks
which one of the b20 blocks has the weak sleeves is it the b20b or b20z.also which one can i use with a set of pistons and rods and boost it maybe 25psi with out it cracking the sleeves,if so has anyone ever attempted this.
Old Nov 8, 2006 | 12:52 PM
lightcrx's Avatar
blocks are the same.... the pistons are differant
Old Nov 8, 2006 | 04:31 PM
b18sihatch's Avatar
Default Re: B20 Blocks (beast59)
b20 wont handle that kinda abuse
Old Nov 9, 2006 | 12:20 AM
Schwebel's Avatar
All B's have crap sleeves, you might be able to run a conservative 6psi on a stock block. But whats the point of swapping internals if your **** is going to blow up and destroy them? Just spend the dough to get it sleeved. Ls block is a better choice for boost if you are on a budget. But no block is going to take 25psi without a good set of sleeves, at least for more than a couple runs down a track. A good resource for B20 info is B20vtec.com.
Old Nov 9, 2006 | 03:39 AM
b18sihatch's Avatar
Default Re: B20 Blocks (Schwebel)
actually that is not true at all.
if you get a b16 or b18 block and run forged internals and low compression with stock sleeves. you could push 16+psi in it even with revitivly higher compression pistons you are still looking at a block that could take 400whp MAX.
if you want over 400whp you need some sleeves.
but even at 350whp you are looking at probably 120mph trap speeds. you dont always need a huge ammount of HP to run a fast quarter
Spoon Si
Dec 2, 2003 05:26 AM
D3LSLO
Aug 24, 2003 09:05 AM
NCHATCH
Acura TL, RL & ZDX
Mar 4, 2003 08:50 AM
1sick4door
Nov 1, 2002 02:12 AM
TypeR0149
Aug 22, 2001 12:32 AM
