Headlight questions for an EG
Old Nov 8, 2006 | 09:19 AM
HondaJack's Avatar
Default Headlight questions for an EG
Does anyone know if there is a headlight for an eg that uses the 9006/9005 headlight set up?
Thanks,
Jack
Old Nov 8, 2006 | 09:42 AM
Padawan's Avatar
Darth ModerVader
Default Re: Headlight questions for an EG (HondaJack)
None that I'm aware of - it would have to be custom. Why are you looking for this?
Old Nov 9, 2006 | 04:35 AM
HondaJack's Avatar
Default Re: Headlight questions for an EG (Padawan)
I wanted to upgrade my lighting without having to invest in HID's.
Old Nov 9, 2006 | 06:49 AM
Padawan's Avatar
Darth ModerVader
There are other ways of doing that without running a headlight that uses a 9006/9005 combination.
Old Nov 9, 2006 | 08:12 AM
deryck324's Avatar
jb weld and silicone
Old Nov 9, 2006 | 10:27 AM
NonovUrbizniz's Avatar
Loved
Default Re: (deryck324)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deryck324 &raquo;</TD></TR><TR><TD CLASS="quote">jb weld and silicone </TD></TR></TABLE>
Silicone completely destroys the plasti-chrome that the headlight reflectors are made of... if you use silicone to reseal your headlights or use it so that fumes in any way get inside the housing be prepared for TERRIBLE lighting...
I couldn't figure out why my headlights were so dim.... until I read somewhere about the silicone killing the relector material... after I swapped them out sure enough... ALL of the nice shiney chrome was dull and cracked/peeled.
Def. don't use silicone.
Old Nov 9, 2006 | 11:03 AM
belly1982's Avatar
NOT sure just go hid
Old Nov 9, 2006 | 01:24 PM
deryck324's Avatar
Default Re: (NonovUrbizniz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NonovUrbizniz &raquo;</TD></TR><TR><TD CLASS="quote">
Def. don't use silicone.</TD></TR></TABLE>
it was a joke i say just get hids
Old Nov 9, 2006 | 01:26 PM
bpr0422's Avatar
From what i've read, there is nothing you can do to improve the eg headlights - other than an HID Retrofit...
NOT just a HID Kit.. a Retrofit with projectors and a CLEAR lenses headlights.
You can buy or retro the TYC One piece, or you can also try and retro ebay projectors
imo: ebay look really crappy...
I say go and buy the Clear Lens TYC replacements, and see if the output is better with those
if not you've done the first step to retrofitting.
Old Nov 9, 2006 | 01:36 PM
Padawan's Avatar
Darth ModerVader
Default Re: Headlight questions for an EG (bpr0422)
If you wanted to stay with halogen, you could also try to source some E-code headlamps from an EDM Civic. Combined with a set of high-performance halogen bulbs such as Philips Vision Plus, they should provide a decent improvement over the stock DOT units.
Old Nov 9, 2006 | 03:16 PM
deryck324's Avatar
what you talking about you can just get h4 style hids and they look fine or you can just get the one peice headlight /corner light that allready set up for hids
EGLUVN
May 15, 2007 09:09 AM
harley06
Dec 23, 2006 11:31 AM
island4drtypeR
Oct 13, 2004 10:45 PM
mikehawkBUiLT
11
May 3, 2004 11:43 AM
