****I have a strange problem I need HELP*******
Old Nov 8, 2006 | 07:17 AM
hybrid98's Avatar
Default ****I have a strange problem I need HELP*******
I purchased a 96 GSR back in July. Already dumped a couple of grand into it to try to fix things (brake master, clutch master, oil pan gasket, compressor, etc.) After a month or so I got a CEL cylinder misfire 1 and 2. I replaced the plugs and wires (Denso Iridium, OEM Wires) thinking that might fix my problem. To my surprise no it didn't. A reputable shop in my area told me that if it had anything to do with the Distributor it would show up a CEL as well. I heard that OBD-2 is so sensitive that the least little thing will set it off. What could be the problem? HELP
this shiot is pissing me off!
Old Nov 8, 2006 | 08:10 AM
hybridej7's Avatar
Default Re: ****I have a strange problem I need HELP******* (hybrid98)
have you checked your timing.....
Old Nov 8, 2006 | 09:06 AM
hybrid98's Avatar
Default Re: ****I have a strange problem I need HELP******* (hybridej7)
if my timing was off, could it be that i could find a little more power? no i have not checked that, good call
anyone else have any thoughts?
Old Nov 8, 2006 | 01:55 PM
hybrid98's Avatar
bump
Old Nov 8, 2006 | 02:59 PM
hybrid98's Avatar
oh yeah i forgot to mention that sometimes it only comes up as cylinder misfire on 2, but never 3 or 4
Old Nov 9, 2006 | 08:16 AM
hybrid98's Avatar
bump
Old Nov 9, 2006 | 08:25 AM
95 integra's Avatar
Did you replace the distributor cap and rotor as well? It is most likely distributor/ignition related as the shop said.
Old Nov 9, 2006 | 10:16 AM
hybrid98's Avatar
Default Re: ****I have a strange problem I need HELP******* (95 integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 integra &raquo;</TD></TR><TR><TD CLASS="quote">Did you replace the distributor cap and rotor as well? It is most likely distributor/ignition related as the shop said.</TD></TR></TABLE>
By that I meant that it would throw a Distributor code sorry for the confusion.
Old Nov 9, 2006 | 11:55 AM
95 integra's Avatar
check the cap and rotor to see what they look like. Since its just one 2 cylinders maybe only those 2 prongs are worn down.
Old Nov 9, 2006 | 01:24 PM
AMLS4dr200whp's Avatar
pm sent
Old Nov 9, 2006 | 03:07 PM
GoldCoin's Avatar
check the coil since your dizzy is out.
Old Nov 10, 2006 | 08:01 AM
hybrid98's Avatar
Default Re: ****I have a strange problem I need HELP******* (DC TWOin IT)
thanks
Old Nov 10, 2006 | 08:45 AM
oneslodx's Avatar
if youve checked all that the next step i would take is a compression check.
Old Nov 10, 2006 | 09:20 AM
CHOWBOX's Avatar
Default Re: (oneslodx)
This may sound weird but I think your problem may be as simple as adjusting your valves. We had a CRV that did this. It came up as a miss fire. The valves were so out of adjustment they were opening late or prematurely, I don’t remember. Anyway it cured the problem. Besides when was the last time you did it??
Old Jun 12, 2007 | 02:55 PM
hybrid98's Avatar
Default Re: (CHOWBOX)
doesn't matter now i fuked it up and it is in the shop
Vince24L
May 14, 2025 10:33 AM
SovereignAce
Jul 1, 2013 03:32 AM
FreshCD5
Dec 1, 2010 03:39 PM
aziaticvang
May 14, 2008 09:04 PM
sleeperteg
Jan 12, 2006 08:46 AM
