Which tranny fluid to use??
Old Nov 8, 2006 | 06:37 AM
CivicSwapper's Avatar
Default Which tranny fluid to use??
Steve at hmotors recommended Redline with an LSD additive but no shops around me carry it. Is there any other recommended brand that has an LSD additive that I can ask for?
Old Nov 8, 2006 | 06:43 AM
Eran's Avatar
HT White Ops
http://www.247-parts.com/view_...RLGFM
Add that to any tranny fluid you prefer.
f20bej1's Avatar
Default Re: Which tranny fluid to use?? (CivicSwapper)
i use lucas oil for my lsd it works great. where i live you get almost 15 passes down the tract and it holds really well to extreme temps.
Old Nov 8, 2006 | 06:47 AM
Default Re: Which tranny fluid to use?? (f20b eg)
trying to find something local. So far the mechanic Im using (good friend) said that none of the shops around us carry redline products. Which is why im trying to find an alternative. After searching, Im seeing a lot of vouches for GM Synchromesh with Friction Modifier. Will this work if I can get my hands on it? Steve said the LSD is a Cusco if that has any bearing
Old Nov 8, 2006 | 06:58 AM
Eran's Avatar
HT White Ops
Lucas is available at any auto parts store.
Synchromesh is available at chevy dealerships.
Old Nov 8, 2006 | 07:17 AM
Default Re: (Eran)
sweet, thanks a lot
Old Nov 8, 2006 | 07:25 AM
Padawan's Avatar
Darth ModerVader
What transmission are you running?
Old Nov 8, 2006 | 07:28 AM
Default Re: Which tranny fluid to use?? (Padawan)
'97 jdm b16 with a Kaaz or Cusco lsd
Old Nov 8, 2006 | 08:06 AM
Mr Hammond's Avatar
a/k/a Jomo
I would first find out what type of LSD you have. Then I would ask said manufacture what they recommend using in your particular transmission with their LSD.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KAAZ USA &raquo;</TD></TR><TR><TD CLASS="quote">Oil for Kaaz LSD
It is important to use 80W/90 GL-5 specification gear oil on Kaaz LSD. We highly recommend using our own Kaaz LSD fluid.
DO NOT USE SYNTHETIC BASE OIL ON KAAZ LSD. Kaaz LSD may not function smoothly.</TD></TR></TABLE>
Old Nov 8, 2006 | 08:27 AM
Default Re: Which tranny fluid to use?? (Mr Hammond)
hmmm... ****, thats what steve told me... "its either a Kaaz or Cusco"
Old Nov 8, 2006 | 08:48 AM
POE's Avatar
POE
ive allways used castrol gtx... and also the oem honda fluid
CivicSwapper
Nov 30, 2006 02:16 PM
weak16teg
Jan 30, 2005 01:04 PM
j87w
Jan 12, 2005 12:36 AM
bmrgold
Sep 16, 2004 03:43 PM
importboi22
Aug 3, 2003 10:20 PM
